Api session event participant net cluster set load attribute
API Endpoint: api/session/event/participant/net_cluster_set_load_attribute/
Description: Stakeholder sets an Attribute to a value, for each Net Load of a Net Cluster
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster | |
| 2 | REQUIRED | (String) | Attribute | |
| 3 | REQUIRED | (Floating point number) | Value |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute", 56 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute", 97 ]'JavaScript example POST
body: '[ 1, 1, "Attribute", 56 ]'
fetch("https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attribute/", options)
