Api session event participant net cluster set states
API Endpoint: api/session/event/participant/net_cluster_set_states/
Description: Stakeholder sets the Net state for all Net Loads of a Net Cluster, per Net Type
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (NET_CLUSTER Integer ID) Net Cluster
2 REQUIRED (NetType or multiple values in array [a, b, c]) Net Types
3 REQUIRED (TimeState or multiple values in array [a, b, c]) Net states (NOTHING, Request_CONSTRUCTION_APPROVAL, Request_ZONING_APPROVAL, READY)
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_states/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "ELECTRICITY", "NOTHING" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_states/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ "ELECTRICITY", "GAS", "HEAT" ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ] ]'
JavaScript example POST
 body: '[ 1, 1, "ELECTRICITY", "NOTHING" ]'
fetch("https://engine.tygron.com/api/session/event/participant/net_cluster_set_states/", options)
