Api session event participant map levee
API Endpoint: api/session/event/participant/map_levee/
Description: Stakeholder plans a Levee for a MultiPolygon, an absolute or relative height and an angle
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (LEVEE Integer ID) | Levee | |
| 2 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | MultiPolygon | |
| 3 | REQUIRED | (Floating point number) | Height in meters | |
| 4 | REQUIRED | (Floating point number) | Angle in degrees | |
| 5 | REQUIRED | (true, false) | Height is relative | true or false |
| 200 | Integer (Action Log ID) |
curl 'https://engine.tygron.com/api/session/event/participant/map_levee/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 99, 99, true ]
'Curl example multi item POST
[ 1, 1, {
}, 78, 80, true ]
'JavaScript example POST
body: '[ 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 99, 99, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/map_levee/?crs=3857", options)
