Api session event participant action menu set active
API Endpoint: api/session/event/participant/action_menu_set_active/
Description: Set an Action Menu active for a Stakeholder
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (ACTION_MENU Integer ID) | Action Menu | |
| 2 | REQUIRED | (true, false) | Active | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/participant/action_menu_set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'JavaScript example POST
body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/action_menu_set_active/", options)
