Api session event editor setting
API Endpoint: api/session/event/editorsetting/
API endpoints for Setting editing.
| Name | Description |
| add_crs | Add Crs |
| get_epoch_time | Get UTC Epoch Time (Milliseconds since 00:00:00 UTC on 1 January 1970) for local Time in this Project |
| get_sun_altitude | Get Sun Altitude value for local Time in this Project |
| get_sun_azimuth | Get Sun Azimuth value for local Time in this Project |
| get_sun_motion | Get Sun Motion value for local Time in this Project (The Netherlands only) |
| remove_crs | Remove Crs |
| set_ai_editing | Set if AI Agents are allowed to edit Project data. |
| set_tql_token | Set if TQL Queries are allowed access the API Token. |
| set_currency | Set Currency |
| set_decimals | Set Decimals |
| set_default_geoplugin | Set Default Geo Plugin |
| set_export_crs | Set Export Crs |
| set_grid_cell_size | Change the project's grid cell size, used by active Overlays. |
| set_import_crs | Set Import Crs |
| set_limit_map | Set Project Map Limit Area |
| set_panel_availability | Set Panel Availability |
| set_permission_popup_active | Set Permission Popup Active |
| set_rasterization | Set Rasterization |
| set_region | Set Region |
| set_setting | Set Project Setting |
| set_sun_dates | Set Sun Dates |
| set_timestamp_format | Set timestamp format |
| set_unit_system_type | Set Unit System Type |
| set_wind_speed | Set Wind Speed |
| wizard_finished | Wizard Finished |
