Current Situation
Current situation is a Map Type (CURRENT) and represents the present situation of your project. Its counterpart is the Planned situation.
Changing the current situation requires the Editor, whereas updating the Planned situation requires an action during a Single, multi or Test Run session.
Items can be present in both map types at the same time. This is the case when starting a single, multi or test-run session. After planning begins, buildings appear only in the planned situation if they are planned or upgraded, and only in the current situation if they are removed.
Buttons in the Top bar of the viewer interface of the Tygron Client allows you to switch between the two Map Types to inspect the differences visually.
Editor
In the Editor the Current situation tab is also the first of the four ribbon tabs and is located in the top part of the editor interface. The Current situation tab contains tools which relate to the editing, configuring and building of the current situation in the project. The current situation is the starting setting for a project before any planning or analysis is to be performed.
The editor. The Current situation tab is located in the ribbon bar at the top of the editor.
The Current situation tab consists of the following tool options:
Conceptually, the current situation contains these Items.
  • The Map Type name of the current situation is CURRENT
API Endpoints
