Clause (TQL)
Revision as of 07:54, 8 July 2026 by Frank@tygron.nl (talk | contribs)
A TQL query statement consists of a command, either Select or Update, and a list of clauses. The clauses provide further specification of the query statement, or a refinement, spatially or property wise.
A clause consists of a clause parameter and a clause value, where currently the only supported operator between the parameter and value is IS.
Spatial
These parameters can be used to limit the search polygon that is used to query Buildings.
Attribute
These parameters are related to Attributes.
Grid
These parameters are specifically related to grids.
Item
These parameters filter for specific types of Items.
Net
These parameter are specific to Network related Items. Some can also be used to limit the selected Buildings.
Property
These parameters primarily filter Building properties, though some apply to other items like Stakeholders.
API Endpoints
