Select lotpolygons (TQL)
| Select | Unit | Description | Fixed clause amount | Polygon based |
| LOTPOLYGONS | polygons | Returns the intersection Polygons between Buildings and the query Polygons | No | true |
Allowed clause parameters
| Param | Value | Description | Limits search polygon |
| AREA |
Integer (Item ID), ID, X, Y, XC, YC, XA, YA, XK or YK |
Area with ID | true |
| AREA_WITH_ATTRIBUTE | Attribute | Area with non zero Attribute value | true |
| ATTRIBUTE | Attribute | The Attribute used for Buildings to obtain a value. | false |
| ATTRIBUTE_MAX | decimal | Only include Buildings that have an Attribute value smaller than this value. | false |
| ATTRIBUTE_MIN | decimal | Only include Buildings that have an Attribute value larger than or equal to this value. | false |
| ATTRIBUTE_MULT | Attribute | Multiply the calculated value with the value of this Attribute for a Building | false |
| BUFFER | decimal | Buffer the limiting search Polygon with this value. | true |
| BUILDING |
Building with ID | false |
| BUILDING_WITH_ATTRIBUTE | Attribute | Building with non zero Attribute value | false |
| CATEGORY |
Category, X, Y, XA, YA |
Category with this value. Buildings of this Category. |
false |
| CATEGORYMULT | Category Value | Multiply the calculated value with this Category Value of a Building | false |
| CRS | positive integer | CRS EPSG number of requested coordinate system | false |
| FUNCTION |
Function with ID | false |
| FUNCTIONMULT | Function Value | Multiply the calculated value with this Function Value of a Building | false |
| GRID |
Grid of Grid Overlay with ID | false |
| GRID_WITH_ATTRIBUTE | Attribute | Grid of Grid Overlay with non zero Attribute value | false |
| GRIDTYPE |
Grid Type, X, Y, XA, YA |
Grid of Grid Overlay with specified type | true |
| GRIDVALUE | decimal | Only include Grid Overlay cells that have a value equal to the one specified | true |
| INDICATOR |
Indicator with ID | false |
| ITERATION | positive integer | Query only executes when the current Iteration matches this value | false |
| KEY | String | Select Attribute based on Overlay Key value | false |
| LAYERTYPE |
Layer, X, Y, XA, YA |
Only include Buildings and Terrains that are part of this Layer | true |
| LEVEE |
Levee with ID | false |
| MAP |
Map Type, X, Y, XA, YA |
Only Items present in this Map Type | true |
| MAXGRIDVALUE | decimal | Only include Grid Overlay cells that have a value smaller than the one specified | true |
| MINGRIDVALUE | decimal | Only include Grid Overlay cells that have a value larger than or equal to the one specified | true |
| NEIGHBORHOOD |
Neighborhood with ID | true |
| NEIGHBORHOOD_WITH_ATTRIBUTE | Attribute | Neighborhood with non zero Attribute value | true |
| NET_CLUSTER |
Net Cluster with ID | true |
| NET_FUNCTION |
Net Function with ID | false |
| NET_LINE |
Net Line with ID | false |
| NET_LOAD |
Net Load with ID | false |
| NET_TYPE |
Net type, X, Y, XA, YA |
Only Net Items of this Net Type | false |
| OVERLAY |
| PANEL |
Panel with ID | false |
| RELATION | Relation | Changes the context of a selected Item to another related Item. | false |
| RESIDENCE | boolean | When true, consider only Buildings that are Residences | false |
| RESULTTYPE |
Result type, X, Y, XA, YA |
Grid of Grid Overlay with specified Result type | true |
| ROAD_SYSTEM | boolean | When true, consider only Buildings that are part of the road system | false |
| SCENARIO |
Scenario with ID | false |
| STAKEHOLDER |
Stakeholder with ID. Only include Plots that are owned by the stakeholder with this ID. Only include Items that are related to this stakeholder. |
true |
| STAKEHOLDERTYPE | Stakeholder Type | Stakeholder Type with this value. Only include Plots that are owned by this type of Stakeholder. |
true |
| STATE | Timestate | Only include Buildings and Measures that are in this Timestate | false |
| TERRAIN |
Terrain of Terrain Type with ID | true |
| TERRAIN_WITH_ATTRIBUTE | Attribute | Terrain is of Terrain Type with non zero Attribute value | true |
| TIMEFRAME |
timeframe, X, Y, XA, YA |
Specifies which Timeframe to select when processing a particular Grid | false |
| ZONE |
Zone with ID | true |
| ZONE_WITH_ATTRIBUTE | Attribute | Zone with non zero Attribute value | true |
- When used in a panel and the panel is opened, the Polygon is highlighted in the 3D Visualization.
API Endpoints
