Clause (TQL)
A TQL query statement consists of a command, either Select or Update, and a list of clauses. The clauses provide further specification of the query statement, or a refinement, spatially or property wise.
A clause consists of a clause parameter and a clause value, where currently the only supported operator between the parameter and value is IS.
Spatial
These parameters can be used to limit the search polygon that is used to query Buildings.
| Param | Value | Description | Limits search polygon |
| AREA |
Integer (Item ID), ID, X, Y, XC, YC, XA, YA, XK or YK |
Area with ID. | true |
| AREA_WITH_ATTRIBUTE | Attribute | Area with non zero Attribute value. | true |
| BUFFER | decimal | Buffer the limiting search Polygon with this value. | true |
| GRIDVALUE | decimal | Only include Grid Overlay cells that have a value equal to the one specified. | true |
| LAYERTYPE |
Layer, X, Y, XA, YA |
Only include Buildings and Terrains that are part of this Layer. | true |
| MAP |
Map Type, X, Y, XA, YA |
Only Items present in this Map Type. | true |
| MAXGRIDVALUE | decimal | Only include Grid Overlay cells that have a value smaller than the one specified. | true |
| MINGRIDVALUE | decimal | Only include Grid Overlay cells that have a value larger than or equal to the one specified. | true |
| NEIGHBORHOOD |
Neighborhood with ID. | true |
| NEIGHBORHOOD_WITH_ATTRIBUTE | Attribute | Neighborhood with non zero Attribute value. | true |
| STAKEHOLDER |
Integer (Item ID), ID, X, Y, XA, YA, XK or YK |
Stakeholder with ID. Only include Plots that are owned by the stakeholder with this ID. Only include Items that are related to this stakeholder. |
true |
| STAKEHOLDERTYPE | Stakeholder Type | Stakeholder Type with this value. Only include Plots that are owned by this type of Stakeholder. |
true |
| TERRAIN |
Terrain of Terrain Type with ID. | true |
| TERRAIN_WITH_ATTRIBUTE | Attribute | Terrain is of Terrain Type with non zero Attribute value. | true |
| ZONE |
Zone with ID. | true |
| ZONE_WITH_ATTRIBUTE | Attribute | Zone with non zero Attribute value. | true |
Attribute
These parameters are related to Attributes.
| ATTRIBUTE | Attribute | The Attribute used for Buildings to obtain a value. | false |
| ATTRIBUTE_MIN | decimal | Only include Buildings that have an Attribute value larger than or equal to this value. | false |
| ATTRIBUTE_MAX | decimal | Only include Buildings that have an Attribute value smaller than this value. | false |
| ATTRIBUTE_MULT | Attribute | Multiply the calculated value with the value of this Attribute for a Building. | false |
| INDEX |
positive integer, X, Y, XA, YA |
Allows to specify which value in an Attribute' s value array to select. | false |
Grid
These parameters are specifically related to grids.
| GRID |
Grid of Grid Overlay with ID. | false |
| GRID_WITH_ATTRIBUTE | Attribute | Grid of Grid Overlay with non zero Attribute value. | false |
| GRIDTYPE |
Grid Type, X, Y, XA, YA |
Grid of Grid Overlay with specified type. | true |
| RESULTTYPE |
Result type, X, Y, XA, YA |
Grid of Grid Overlay with specified Result type. | true |
| TIMEFRAME |
timeframe, X, Y, XA, YA |
Specifies which Timeframe to select when processing a particular Grid. | false |
Item
These parameter can be used to consider only a specific Item of that kind.
| ADDRESS |
Address with ID. | false |
| AREA |
| BUILDING |
Building with ID. | false |
| BUILDING_WITH_ATTRIBUTE | Attribute | Building with non zero Attribute value. | false |
| FUNCTION |
Function with ID. | false |
| GLOBAL |
Global with ID. | false |
| GRID |
| INDICATOR |
Indicator with ID. | false |
| LEVEE |
Levee with ID. | false |
| MEASURE |
Measure with ID. | false |
| NEIGHBORHOOD |
| OVERLAY |
| PANEL |
Panel with ID. | false |
| RELATION | Relation | Changes the context of a selected Item to another related Item. | false |
| STAKEHOLDER |
true |
| TERRAIN |
| ZONE |
Net
These parameter are specific to Network related Items. Some can also be used to limit the selected Buildings.
| NET_LINE |
Net Line with ID. | false |
| NET_TYPE |
Net type, X, Y, XA, YA |
Only Net Items of this Net Type. | false |
| NET_FUNCTION |
Net Function with ID. | false |
| NET_LOAD |
Net Load with ID. | false |
| NET_CLUSTER |
Net Cluster with ID. | true |
Property
These parameters are mostly related to Building properties to filter on, but also include properties related to and shared with other items, such as Stakeholders.
| CATEGORY |
Category, X, Y, XA, YA |
Category with this value. Buildings of this Category. |
false |
| CATEGORYMULT | Category Value | Multiply the calculated value with this Category Value of a Building. | false |
| CRS | positive integer | CRS EPSG number of requested coordinate system. | false |
| FUNCTIONMULT | Function Value | Multiply the calculated value with this Function Value of a Building. | false |
| ITERATION | positive integer | Query only executes when the current Iteration matches this value. | false |
| KEY | String | Select Attribute based on Overlay Key value. | false |
| LAYERTYPE |
| MAP |
| NAME | String | Select Attribute or Global with specified name. | false |
| RESIDENCE | boolean | When true, consider only Buildings that are Residences. | false |
| ROAD_SYSTEM | boolean | When true, consider only Buildings that are part of the road system. | false |
true |
| STATE | Timestate | Only include Buildings and Measures that are in this Timestate. | false |
| TERM |
Client Word, Server Word |
Client Word or Server Word with name. | false |
API Endpoints
