Api session event editor building query
API Endpoint: api/session/event/editorbuilding/query/
Description: Execute a single TQL Query. Use the Session/query Endpoint for multiple statements or detailed API usage information
| 0 | REQUIRED | (String) | TQL Query Statement | |
| 1 | OPTIONAL | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Value for update queries (optional) |
| 200 | Object (Query result) |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TQL Query Statement"'JavaScript example POST
body: '"TQL Query Statement"'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/query/", options)
