Aquifer (Water Overlay)
Revision as of 12:23, 9 June 2026 by Frank@tygron.nl (talk | contribs)
The aquifer is an additional definition for the ground, allowing for ground horizontal flow different from the ground terrain's GROUND_INFILTRATION_MD.
  • The aquifer only functions if its hydraulic conductivity is greater than 0. If it is 0 or less the aquifer is disregarded, and the GROUND_INFILTRATION_MD of the ground terrain is used.
  • The aquifer functionality is also used to model drainages.
  • *Overlapping Aquifers are not allowed. Should in any location two or more Aquifers overlap, the values of one of them is used, and the values of the others are ignored.
