Api session event editor measure
API Endpoint: api/session/event/editormeasure/
API endpoints for Measure editing.
| Name | Description |
| add | Add Measure for Stakeholder |
| duplicate | Duplicate specified Measures. |
| remove | Remove specified Measures. |
| set_name | Set the name of a Measure. |
Additional API endpoints:
| add_building | Add a new Building to specified Measures |
| add_event | Add a new event to a Measure for a specific Action Type. |
| add_geotiff | Add a new GeoTIFF Spatial to a Measure. |
| add_geotiff_polygons | Add Polygons to existing Polygons of a GeoTIFF Spatial of a Measure. |
| add_grid | Add a new Grid Spatial to a Measure. |
| add_grid_polygons | Add Polygons to existing Polygons of a Grid Spatial of a Measure. |
| add_levee | Add a new Levee Spatial of a specified Levee to a Measure. |
| add_levee_polygons | Add Polygons to existing outer (or inner) Polygons of a Levee Spatial of a Measure. |
| add_terrain | Add a new Terrain Spatial to a Measure. |
| add_terrain_polygons | Add Polygons to existing outer (or inner) Polygons of a Terrain Spatial of a Measure. |
| add_upgrade | Add a new Upgrade Spatial to a Measure. |
| add_upgrade_polygons | Add Polygons to existing Polygons of an Upgrade Spatial of a Measure. |
| duplicate_building | Duplicate specified Measure Buildings. |
| import_buildings | Import Measure Building Collection |
| import_geotiffs | Import Measure GeoTIFF Collection |
| import_grids | Import Measure Grid Collection |
| import_levees | Import Measure Levee Collection |
| import_terrains | Import Measure Terrain Collection |
| import_upgrades | Import Measure Upgrade Collection |
| remove_event | Add a specific event of a Measure for a specific Action Type. |
| remove_geotiff | Remove specified GeoTIFF Spatial from a Measure. |
| remove_geotiff_polygons | Remove Polygons from existing Polygons of a GeoTIFFs Spatial of a Measure. |
| remove_geotiff_terrain_type | Remove the Terrain Type of a GeoTIFF Spatial of a Measure. |
| remove_grid | Remove specified Grid Spatial from a Measure. |
| remove_grid_polygons | Remove Polygons from existing Polygons of a Grid Spatial of a Measure. |
| remove_grid_terrain_type | Remove the Terrain Type of a Grid Spatial of a Measure. |
| remove_levee | Remove specified Levee Spatials from a Measure. |
| remove_levee_polygons | Remove Polygons from existing Polygons of a Levee Spatial of a Measure. |
| remove_terrain | Remove specified Terrain Spatials from a Measure. |
| remove_terrain_polygons | Remove Polygons from existing outer (or inner) Polygons of a Terrain Spatial of a Measure. |
| remove_upgrade | Remove specified Upgrade Spatials from a Measure. |
| remove_upgrade_polygons | Remove Polygons from existing Polygons of a Upgrade Spatial of a Measure. |
| set_cost | Set the Costs of a Measure of a particular Cost type (construction, demolition) and wether it is fixed or Cost per cubic meter. |
| set_description | Set the description of a Measure. |
| set_event | Change an existing event of a specific Action Type of a Measure. |
| set_geotiff | Change the GeoTIFFs applied by a specified Measure. |
| set_geotiff_automatic_polygons | Let the Polygons be calculated automatically based on the GeoTIFFs specified in the GeoTIFF spatial of a Measure. |
| set_geotiff_terrain_type | Set the Terrain Type for a GeoTIFF Spatial of a Measure. |
| set_grid | Change the Grids applied by a specified Measure. |
| set_grid_automatic_polygons | Let the Polygons be calculated automatically based on the Overlay specified in the Grid spatial of a Measure. |
| set_grid_terrain_type | Set the Terrain Type for a Grid Spatial of a Measure. |
| set_image | Set the image of a Measure. |
| set_levee_angle | Set the angle of Levee Spatial of a Measure. |
| set_levee_height | Set the inner height of Levee Spatial of a Measure. |
| set_levee_height_relative | Set whether the inner height of Levee Spatial of a Measure is considered relative. |
| set_levee_type | Set the Levee for a specified Levee Spatial of a Measure. |
| set_owner | Set the owner of a Measure. |
| set_requires_confirmation | Set whether the Measure should be confirmed by other Stakeholders. |
| set_terrain_edit_type | Set the Edit Type of a Terrain Spatial of a Measure. This changes the way the Terrain height is adjusted: lowered, flattened or raised. |
| set_terrain_height | Set the inner height of Terrain Spatial of a Measure. |
| set_terrain_height_relative | Set whether the inner height of Terrain Spatial of a Measure is considered relative. |
| set_terrain_type | Set the Terrain Type for a Terrain Spatial of a Measure. |
| set_upgrade_type | Set the Upgrade Type for an Upgrade Spatial of a Measure. |
