Api session event editor measure
Api session event editor measure Endpoints.
API EndPoints for Measure editing.
Name Description
add Add Measure for Stakeholder
duplicate Duplicate specified Measures.
remove Remove specified Measures.
set_name Set the name of a Measure.
Additional API EndPoints:
Name Description
add_building Add a new Building to specified Measures
add_event Add a new event to a Measure for a specific Action Type.
add_geotiff Add a new GeoTIFF Spatial to a Measure.
add_geotiff_polygons Add Polygons to existing Polygons of a GeoTIFF Spatial of a Measure.
add_grid Add a new Grid Spatial to a Measure.
add_grid_polygons Add Polygons to existing Polygons of a Grid Spatial of a Measure.
add_levee Add a new Levee Spatial of a specified Levee to a Measure.
add_levee_polygons Add Polygons to existing outer (or inner) Polygons of a Levee Spatial of a Measure.
add_terrain Add a new Terrain Spatial to a Measure.
add_terrain_polygons Add Polygons to existing outer (or inner) Polygons of a Terrain Spatial of a Measure.
add_upgrade Add a new Upgrade Spatial to a Measure.
add_upgrade_polygons Add Polygons to existing Polygons of an Upgrade Spatial of a Measure.
duplicate_building Duplicate specified Measure Buildings.
import_buildings Import Measure Building Collection
import_geotiffs Import Measure GeoTIFF Collection
import_grids Import Measure Grid Collection
import_levees Import Measure Levee Collection
import_terrains Import Measure Terrain Collection
import_upgrades Import Measure Upgrade Collection
remove_event Add a specific event of a Measure for a specific Action Type.
remove_geotiff Remove specified GeoTIFF Spatial from a Measure.
remove_geotiff_polygons Remove Polygons from existing Polygons of a GeoTIFFs Spatial of a Measure.
remove_geotiff_terrain_type Remove the Terrain Type of a GeoTIFF Spatial of a Measure.
remove_grid Remove specified Grid Spatial from a Measure.
remove_grid_polygons Remove Polygons from existing Polygons of a Grid Spatial of a Measure.
remove_grid_terrain_type Remove the Terrain Type of a Grid Spatial of a Measure.
remove_levee Remove specified Levee Spatials from a Measure.
remove_levee_polygons Remove Polygons from existing Polygons of a Levee Spatial of a Measure.
remove_terrain Remove specified Terrain Spatials from a Measure.
remove_terrain_polygons Remove Polygons from existing outer (or inner) Polygons of a Terrain Spatial of a Measure.
remove_upgrade Remove specified Upgrade Spatials from a Measure.
remove_upgrade_polygons Remove Polygons from existing Polygons of a Upgrade Spatial of a Measure.
set_cost Set the Costs of a Measure of a particular Cost type (construction, demolition) and wether it is fixed or Cost per cubic meter.
set_description Set the description of a Measure.
set_event Change an existing event of a specific Action Type of a Measure.
set_geotiff Change the GeoTIFFs applied by a specified Measure.
set_geotiff_automatic_polygons Let the Polygons be calculated automatically based on the GeoTIFFs specified in the GeoTIFF spatial of a Measure.
set_geotiff_terrain_type Set the Terrain Type for a GeoTIFF Spatial of a Measure.
set_grid Change the Grids applied by a specified Measure.
set_grid_automatic_polygons Let the Polygons be calculated automatically based on the Overlay specified in the Grid spatial of a Measure.
set_grid_terrain_type Set the Terrain Type for a Grid Spatial of a Measure.
set_image Set the image of a Measure.
set_levee_angle Set the angle of Levee Spatial of a Measure.
set_levee_height Set the inner height of Levee Spatial of a Measure.
set_levee_height_relative Set whether the inner height of Levee Spatial of a Measure is considered relative.
set_levee_type Set the Levee for a specified Levee Spatial of a Measure.
set_owner Set the owner of a Measure.
set_requires_confirmation Set whether the Measure should be confirmed by other Stakeholders.
set_terrain_edit_type Set the Edit Type of a Terrain Spatial of a Measure. This changes the way the Terrain height is adjusted: lowered, flattened or raised.
set_terrain_height Set the inner height of Terrain Spatial of a Measure.
set_terrain_height_relative Set whether the inner height of Terrain Spatial of a Measure is considered relative.
set_terrain_type Set the Terrain Type for a Terrain Spatial of a Measure.
set_upgrade_type Set the Upgrade Type for an Upgrade Spatial of a Measure.
