Api session event participant
Api session event participant Endpoints.
API Endpoints for Endpoints for user actions (e.g. build Building) in a testrun/impact Session.
Name Description
action_menu_set_active Set a category active for a Stakeholder.
attribute_action_plan Apply an Attribute Action.
building_plan_construction Plan a new Building in the MAQUETTE map.
building_plan_demolish Plan the demolition of a Building in the MAQUETTE map.
building_plan_demolish_polygon Plan the demolition of a Building in the given polygon in the MAQUETTE map.
building_plan_upgrade Plan the upgrade of Building in the given polygon in the MAQUETTE map.
building_revert_polygon Revert polygon to orginal CURRENT map situation.
event_bundle_apply_server_events Apply a bundle of events on the serverside for a particular Stakeholder.
map_buy_land Buy the land definied by the polygon for given price.
map_levee Create a Levee with a given height and Area.
map_lower_land Lower land to create open water.
map_raise_land Raise land by one length unit.
map_sell_land Buy the land definied by the polygon for given price.
measure_cancel_construction Cancel a Measure planned by an Stakeholder while in pre-construction phase.
measure_plan_construction Plan construction of a Measure by an Stakeholder that is not yet planned.
money_transfer_give Give money from one Stakeholder to another.
net_cluster_set_load_attribute For each Net Load of a Net Cluster, set the value of the attribute.
net_cluster_set_load_attributes For each Net Load of a Net Cluster, set the value of the attribute.
net_cluster_set_state Set Timestate for all Net Load of Net Cluster.
net_cluster_set_state_for_net_type Set Timestate for Net Load of Net Cluster, based on Net Type.
net_cluster_set_states Set Timestate for all Net Load of Net Cluster.
panel_answer Stakeholder has selected an answer in a Panel.
parametric_design_plan Parametric Design Plan
popup_answer Stakeholder answers a Popup.
popup_answer_with_date Stakeholder answers a Popup with an additional date.
restore_land Stakeholder restores land back to orginal state.
stakeholder_set_location Set the location of a Stakeholder in the 3D world.
zone_add_function_category Add a FunctionCategory that is allowed to be built within a Zone.
zone_remove_function_category Remove a FunctionCategory so it cannot be build within the Zone.
zones_set_categories Sets the allowed Building categories for specified Zone.
