Terrain Type
Terrain types are definitions of how the ground behaves. Oftentimes, the (sub)soil consists of a mixture of various types of material. Each individual material can be considered a type of terrain, the combination of materials can be considered a type of terrain as well.
Terrain Types in the Tygron Platform are abstract definitions of either a surface or ground composition of the Terrain. In other words, every Terrain Type belongs either to the surface layer or the underground layer. Each Terrain Type has a series of Attributes defining its exact properties and behavior, both for functionalities such as the generation of the default elevation model, as well as for calculation models ranging from the Average Overlay to the Water Overlay.
Terrain types do not contains spatial information. Instead they form an integral part of Terrains, which themselves do contain spatial information. Every Terrain item links to one Terrain Type, which in turn determines in what layer the Terrain is situated.
Surface
Surface Terrain Types represent the soil as as it lies on the very top of the Terrain. It is often a single layer such as Grassland, Concrete, or a Waterway. In most cases, the surface Terrain Type also affects the visualization of the height-map in the 3D Visualization. Water is most obvious, as water will be drawn on top of the existing Terrain. However, all Terrain Types have a set texture which will be shown in any location where the Terrain is changed for a different Terrain Type. (Otherwise the default satellite map will be visible.)
The following Terrain Types exist for the surface: This page contains a list of summarized Terrain Types, available to all projects. The defaults are also mentioned below.
| Name | ID | Inherits from | Code |
| Breakwater | 5 | ||
| Concrete | 8 | ||
| Dike | 6 | ||
| Dunes | 7 | ||
| Grassland | 1 | ||
| Open Land | 0 | ||
| Sand | 4 | ||
| Sea | 19 | ||
| Waterbody | 20 | ||
| Waterway | 3 |
Underground Terrain Types
| Chalk | 15 | ||
| Clay | 10 | ||
| Gravel | 18 | ||
| Loam | 16 | ||
| Loess | 13 | ||
| Marine Clay | 14 | ||
| Peat | 12 | ||
| Sand (subsurface) | 11 | ||
| Silt | 17 | ||
| Unknown | 9 | ||
| Afgegraven | 147 | Unknown | b AFGRAV |
| Bebouwing | 161 | Unknown | h BEBOUW |
| Bovenland | 162 | Unknown | i BOVLAND |
| Geegaliseerd | 174 | Unknown | |
| Groeve | 175 | Unknown | a GROEVE |
| Gronden in oude maasmeanders | 128 | Unknown | AMm |
| Kreekbeddingen | 125 | Unknown | AK |
| Met huisvuil opgehoogde gronden | 131 | Unknown | AQ |
| Mijnstort | 216 | Unknown | j MYNSTRT |
| Moeras | 238 | Unknown | g MOERAS |
| Opgehoogd of opgespoten | 243 | Unknown | c OPHOOG |
| Oude bewoningsplaatsen (terpen en woerden) | 244 | Unknown | f TERP |
| Roergronden | 132 | Unknown | AR |
| Sterk vergraven | 276 | Unknown | |
| Terras-, tertiair-, kalksteen- en veenhellinggronden | 123 | Unknown | AHv |
| Terrashellinggronden | 122 | Unknown | AHt |
| Verwerk | 422 | Unknown | e VERWERK |
| Warmoezerijgronden (gerijpt) | 137 | Unknown | AWg |
| Warmoezerijgronden (ongerijpt) | 138 | Unknown | AWo |
| Water | 286 | Unknown | g WATER |
| Waterkerende dijk | 287 | Unknown | h DIJK |
| Afgegraven kleigronden | 100 | Clay | AAK |
| Fluviatiele afzettingen ouder dan laat-pleistoceen; zavel en klei | 173 | Clay | FK |
| Gorsvaaggronden; zware zavel en rivierklei; geen zand beginnend ondieper dan 80 cm | 246 | Clay | ROb75 |
| Gorsvaaggronden; zware zavel en zeeklei; geen zand beginnend ondieper dan 80 cm | 210 | Clay | MOb75 |
| Kalkarme drechtvaaggronden; zavel en lichte klei, profielverloop 1 | 241 | Clay | Mv61C |
| Kalkarme drechtvaaggronden; zware klei, profielverloop 1 | 239 | Clay | Mv41C |
| Kalkarme leek-/woudeerdgronden; klei, profielverloop 2 | 380 | Clay | pMn82C |
| Kalkarme leek-/woudeerdgronden; klei, profielverloop 3, of 3 en 4, of 4 | 383 | Clay | pMn86C |
| Kalkarme leek-/woudeerdgronden; klei, profielverloop 5 | 382 | Clay | pMn85C |
| Kalkarme nesvaaggronden; klei | 237 | Clay | Mo80C |
| Kalkarme poldervaaggronden; klei, profielverloop 2 | 229 | Clay | Mn82C |
| Kalkarme poldervaaggronden; klei, profielverloop 3, of 3 en 4, of 4 | 232 | Clay | Mn86C |
| Kalkarme poldervaaggronden; klei, profielverloop 5 | 230 | Clay | Mn85C |
| Kalkhoudend poldervaaggronden; klei, profielverloop 2 | 264 | Clay | Rn82A |
| Kalkhoudende drechtvaaggronden; profielverloop 1 | 272 | Clay | Rv01A |
| Kalkhoudende nesvaaggronden; zavel en lichte klei | 270 | Clay | Ro60A |
| Kalkhoudende nesvaaggronden; zware klei | 268 | Clay | Ro40A |
| Kalkhoudende ooivaaggronden; zware zavel en lichte klei | 249 | Clay | Rd90A |
| Kalkhoudende poldervaaggronden; zavel en lichte klei, profielverloop 3, of 3 en 4, of 4 | 262 | Clay | Rn66A |
| Kalkhoudende poldervaaggronden; zware klei, profielverloop 3, of 3 en 4, of 4 | 258 | Clay | Rn46A |
| Kalkhoudende poldervaaggronden; zware klei, profielverloop 5 | 256 | Clay | Rn45A |
| Kalkhoudende poldervaaggronden; zware zavel en lichte klei, profielverloop 5 | 266 | Clay | Rn95A |
| Kalkloze drechtvaaggronden; profielverloop 1 | 273 | Clay | Rv01C |
| Kalkloze nesvaaggronden; zavel en lichte klei | 271 | Clay | Ro60C |
| Kalkloze nesvaaggronden; zware klei | 269 | Clay | Ro40C |
| Kalkloze ooivaaggronden; zware zavel en lichte klei | 250 | Clay | Rd90C |
| Kalkloze poldervaaggronden (bruine komgrond); zware klei, profielverloop 3, of 3 en 4, of 4 | 322 | Clay | bRn46C |
| Kalkloze poldervaaggronden; zavel en lichte klei, profielverloop 2 | 261 | Clay | Rn62C |
| Kalkloze poldervaaggronden; zavel en lichte klei, profielverloop 3, of 3 en 4 | 263 | Clay | Rn67C |
| Kalkloze poldervaaggronden; zware klei, profielverloop 2 | 254 | Clay | Rn42C |
| Kalkloze poldervaaggronden; zware klei, profielverloop 3, of 3 en 4 | 259 | Clay | Rn47C |
| Kalkloze poldervaaggronden; zware klei, profielverloop 4 | 255 | Clay | Rn44C |
| Kalkloze poldervaaggronden; zware klei, profielverloop 5 | 257 | Clay | Rn45C |
| Kalkloze poldervaaggronden; zware zavel en lichte klei, profielverloop 4 | 265 | Clay | Rn94C |
| Kalkloze poldervaaggronden; zware zavel en lichte klei, profielverloop 5 | 267 | Clay | Rn95C |
| Kalkrijke drechtvaaggronden; klei, profielverloop 1 | 242 | Clay | Mv81A |
| Kalkrijke leek-/woudeerdgronden; klei, profielverloop 2 | 379 | Clay | pMn82A |
| Kalkrijke leek-/woudeerdgronden; klei, profielverloop 5 | 381 | Clay | pMn85A |
| Kalkrijke nesvaaggronden; klei | 236 | Clay | Mo80A |
| Kalkrijke poldervaaggronden; klei, profielverloop 2 | 228 | Clay | Mn82A |
| Kalkrijke poldervaaggronden; klei, profielverloop 3, of 3 en 4, of 4 | 231 | Clay | Mn86A |
| Kalkrijke poldervaaggronden; lichte klei, profielverloop 5 | 223 | Clay | Mn35A |
| Kalkrijke poldervaaggronden; zware klei, profielverloop 5 | 224 | Clay | Mn45A |
| Kleiige beekdalgronden | 102 | Clay | ABk |
| Knippige poldervaaggronden; klei, profielverloop 2 | 340 | Clay | gMn82C |
| Knippige poldervaaggronden; klei, profielverloop 3 | 341 | Clay | gMn83C |
| Knippige poldervaaggronden; klei, profielverloop 4, of 4 en 3 | 343 | Clay | gMn88C |
| Knippige poldervaaggronden; klei, profielverloop 5 | 342 | Clay | gMn85C |
| Knippoldervaaggronden; zavel en lichte klei, profielverloop 3 | 360 | Clay | kMn63C |
| Knippoldervaaggronden; zavel en lichte klei, profielverloop 4, of 4 en 3 | 361 | Clay | kMn68C |
| Knippoldervaaggronden; zware klei, profielverloop 3 | 358 | Clay | kMn43C |
| Knippoldervaaggronden; zware klei, profielverloop 4, of 4 en 3 | 359 | Clay | kMn48C |
| Leek-/woudeerdgronden; klei, profielverloop 3, of 3 en 4, of 4 | 390 | Clay | pRn86 |
| Leek-/woudeerdgronden; klei, profielverloop 5, of 5 en 2, of 2 | 391 | Clay | pRn89 |
| Liedeerdgronden; klei, profielverloop 1 | 387 | Clay | pMv81 |
| Liedeerdgronden; klei, profielverloop 1 | 392 | Clay | pRv81 |
| Linge- uiterwaardgronden | 126 | Clay | ALu |
| Ooivaaggronden; zware zavel en klei | 185 | Clay | KRd7 |
| Overige kleigronden | 190 | Clay | KT |
| Poldervaaggronden; klei | 188 | Clay | KRn8 |
| Roodoornige kleiige Vechtdalgronden | 114 | Clay | AFk |
| Slikvaaggronden; geen zand beginnend ondieper dan 80 cm | 212 | Clay | MOo05 |
| Tochteerdgronden; klei | 385 | Clay | pMo80 |
| Tuineerdgronden; zware zavel en klei, profielverloop 3, of 3 en 4, of 4 | 164 | Clay | EK76 |
| Tuineerdgronden; zware zavel en klei, profielverloop 5, of 5 en 2, of 2 | 165 | Clay | EK79 |
| Wieringermeergronden; klei, kalkrijk | 146 | Clay | AZW8A |
| Wieringermeergronden; zavel en klei, kalkrijk | 144 | Clay | AZW6A |
| Wieringermeergronden; zware zavel en klei, kalkrijk | 145 | Clay | AZW7A |
| Akkereerdgronden; grof zand | 334 | Sand (subsurface) | cZd30 |
| Akkereerdgronden; leemarm en zwak lemig fijn zand | 332 | Sand (subsurface) | cZd21 |
| Akkereerdgronden; lemig fijn zand | 333 | Sand (subsurface) | cZd23 |
| Beekeerdgronden; grof zand | 403 | Sand (subsurface) | pZg30 |
| Beekeerdgronden; leemarm en zwak lemig fijn zand | 401 | Sand (subsurface) | pZg21 |
| Beekeerdgronden; lemig fijn zand | 402 | Sand (subsurface) | pZg23 |
| Duin- en kweldergronden | 106 | Sand (subsurface) | AD |
| Duinvaaggronden; grof zand | 303 | Sand (subsurface) | Zd30 |
| Duinvaaggronden; leemarm en zwak lemig fijn zand | 301 | Sand (subsurface) | Zd21 |
| Duinvaaggronden; lemig fijn zand | 302 | Sand (subsurface) | Zd23 |
| Fluviatiele afzettingen ouder dan laat-pleistoceen; grind en grof zand | 172 | Sand (subsurface) | FG |
| Glauconiet hellinggronden | 117 | Sand (subsurface) | AHa |
| Gooreerdgronden; grof zand | 406 | Sand (subsurface) | pZn30 |
| Gooreerdgronden; leemarm en zwak lemig fijn zand | 404 | Sand (subsurface) | pZn21 |
| Gooreerdgronden; lemig fijn zand | 405 | Sand (subsurface) | pZn23 |
| Gorsvaaggronden; lichte zavel; zand beginnend ondieper dan 80 cm | 207 | Sand (subsurface) | MOb12 |
| Gorsvaaggronden; zware zavel en rivierklei; zand beginnend ondieper dan 80 cm | 245 | Sand (subsurface) | ROb72 |
| Gorsvaaggronden; zware zavel en zeeklei; zand beginnend ondieper dan 80 cm | 209 | Sand (subsurface) | MOb72 |
| Haarpodzolgronden; grof zand | 178 | Sand (subsurface) | Hd30 |
| Haarpodzolgronden; leemarm en zwak lemig fijn zand | 176 | Sand (subsurface) | Hd21 |
| Hoge bruine enkeerdgronden; grof zand | 321 | Sand (subsurface) | bEZ30 |
| Hoge bruine enkeerdgronden; leemarm en zwak lemig fijn zand | 319 | Sand (subsurface) | bEZ21 |
| Hoge bruine enkeerdgronden; lemig fijn zand | 320 | Sand (subsurface) | bEZ23 |
| Hoge zwarte enkeerdgronden; grof zand | 415 | Sand (subsurface) | zEZ30 |
| Hoge zwarte enkeerdgronden; leemarm en zwak lemig fijn zand | 413 | Sand (subsurface) | zEZ21 |
| Hoge zwarte enkeerdgronden; lemig fijn zand | 414 | Sand (subsurface) | zEZ23 |
| Holtpodzolgronden; grof zand | 293 | Sand (subsurface) | Y30 |
| Holtpodzolgronden; leemarm en zwak lemig fijn zand | 290 | Sand (subsurface) | Y21 |
| Holtpodzolgronden; lemig fijn zand | 291 | Sand (subsurface) | Y23 |
| Horstpodzolgronden; lemig fijn zand | 292 | Sand (subsurface) | Y23b |
| Kalkarme leek-/woudeerdgronden; zavel, profielverloop 2 | 375 | Sand (subsurface) | pMn52C |
| Kalkarme leek-/woudeerdgronden; zavel, profielverloop 3, of 3 en 4, of 4 | 378 | Sand (subsurface) | pMn56C |
| Kalkarme leek-/woudeerdgronden; zavel, profielverloop 5 | 377 | Sand (subsurface) | pMn55C |
| Kalkarme nesvaaggronden; zavel | 235 | Sand (subsurface) | Mo50C |
| Kalkarme poldervaaggronden; lichte zavel, profielverloop 5 | 219 | Sand (subsurface) | Mn15C |
| Kalkarme poldervaaggronden; zavel, profielverloop 2 | 225 | Sand (subsurface) | Mn52C |
| Kalkarme poldervaaggronden; zavel, profielverloop 3, of 3 en 4 of 4 | 227 | Sand (subsurface) | Mn56C |
| Kalkarme poldervaaggronden; zware zavel; profielverloop 5 | 222 | Sand (subsurface) | Mn25C |
| Kalkhoudende beekeerdgronden; zeer fijn en matig fijn zand | 400 | Sand (subsurface) | pZg20A |
| Kalkhoudende duinvaaggronden; fijn zand | 299 | Sand (subsurface) | Zd20A |
| Kalkhoudende duinvaaggronden; fijn zand met ontkalkte bovengrond | 300 | Sand (subsurface) | Zd20Ab |
| Kalkhoudende duinvaaggronden; grof zand | 304 | Sand (subsurface) | Zd30A |
| Kalkhoudende enkeerdgronden; matig fijn zand | 167 | Sand (subsurface) | EZ50A |
| Kalkhoudende ooivaaggronden; lichte zavel | 247 | Sand (subsurface) | Rd10A |
| Kalkhoudende poldervaaggronden; lichte zavel, profielverloop 5 | 252 | Sand (subsurface) | Rn15A |
| Kalkhoudende poldervaaggronden; zavel, profielverloop 2 | 260 | Sand (subsurface) | Rn52A |
| Kalkhoudende vlakvaaggronden, grof zand met ontkalkte bovengrond | 310 | Sand (subsurface) | Zn30Ab |
| Kalkhoudende vlakvaaggronden, matig fijn zand met ontkalkte bovengrond | 314 | Sand (subsurface) | Zn50Ab |
| Kalkhoudende vlakvaaggronden; grof zand | 309 | Sand (subsurface) | Zn30A |
| Kalkhoudende vlakvaaggronden; matig fijn zand | 312 | Sand (subsurface) | Zn50A |
| Kalkhoudende vlakvaaggronden; uiterst fijn zand | 305 | Sand (subsurface) | Zn10A |
| Kalkhoudende vlakvaaggronden; zeer fijn zand | 311 | Sand (subsurface) | Zn40A |
| Kalkhoudende vorstvaaggronden; fijn zand | 294 | Sand (subsurface) | Zb20A |
| Kalkhoudende vorstvaaggronden; grof zand | 298 | Sand (subsurface) | Zb30A |
| Kalkloze ooivaaggronden; lichte zavel | 248 | Sand (subsurface) | Rd10C |
| Kalkloze poldervaaggronden; lichte zavel, profielverloop 4 | 251 | Sand (subsurface) | Rn14C |
| Kalkloze poldervaaggronden; lichte zavel, profielverloop 5 | 253 | Sand (subsurface) | Rn15C |
| Kalkrijke drechtvaaggronden; zavel, profielverloop 1 | 240 | Sand (subsurface) | Mv51A |
| Kalkrijke leek-/woudeerdgronden; zavel, profielverloop 2 | 374 | Sand (subsurface) | pMn52A |
| Kalkrijke leek-/woudeerdgronden; zavel, profielverloop 5 | 376 | Sand (subsurface) | pMn55A |
| Kalkrijke nesvaaggronden; lichte zavel | 233 | Sand (subsurface) | Mo10A |
| Kalkrijke nesvaaggronden; zware zavel | 234 | Sand (subsurface) | Mo20A |
| Kalkrijke poldervaaggronden; lichte zavel, profielverloop 2 | 217 | Sand (subsurface) | Mn12A |
| Kalkrijke poldervaaggronden; lichte zavel, profielverloop 5 | 218 | Sand (subsurface) | Mn15A |
| Kalkrijke poldervaaggronden; zavel, profielverloop 3, of 3 en 4 of 4 | 226 | Sand (subsurface) | Mn56A |
| Kalkrijke poldervaaggronden; zware zavel; profielverloop 2 | 220 | Sand (subsurface) | Mn22A |
| Kalkrijke poldervaaggronden; zware zavel; profielverloop 5 | 221 | Sand (subsurface) | Mn25A |
| Kamppodzolgronden; grof zand | 325 | Sand (subsurface) | cHd30 |
| Kamppodzolgronden; leemarm en zwak lemig fijn zand | 323 | Sand (subsurface) | cHd21 |
| Kamppodzolgronden; lemig fijn zand | 324 | Sand (subsurface) | cHd23 |
| Kanteerdgronden; grof zand | 409 | Sand (subsurface) | tZd30 |
| Kanteerdgronden; leemarm en zwak lemig fijn zand | 407 | Sand (subsurface) | tZd21 |
| Kanteerdgronden; lemig fijn zand | 408 | Sand (subsurface) | tZd23 |
| Knippige poldervaaggronden; lichte zavel, profielverloop 5 | 335 | Sand (subsurface) | gMn15C |
| Knippige poldervaaggronden; zavel, profielverloop 2 | 337 | Sand (subsurface) | gMn52C |
| Knippige poldervaaggronden; zavel, profielverloop 3 | 338 | Sand (subsurface) | gMn53C |
| Knippige poldervaaggronden; zavel, profielverloop 4, of 4 en 3 | 339 | Sand (subsurface) | gMn58C |
| Knippige poldervaaggronden; zware zavel, profielverloop 5 | 336 | Sand (subsurface) | gMn25C |
| Laarpodzolgronden; grof zand | 328 | Sand (subsurface) | cHn30 |
| Laarpodzolgronden; leemarm en zwak lemig fijn zand | 326 | Sand (subsurface) | cHn21 |
| Laarpodzolgronden; lemig fijn zand | 327 | Sand (subsurface) | cHn23 |
| Lage enkeerdgronden; grof zand | 170 | Sand (subsurface) | EZg30 |
| Lage enkeerdgronden; leemarm en zwak lemig fijn zand | 168 | Sand (subsurface) | EZg21 |
| Leek-/woodeerdgronden; zavel, profielverloop 3, of 3 en 4, of 4 | 388 | Sand (subsurface) | pRn56 |
| Leek-/woodeerdgronden; zavel, profielverloop 5, of 5 en 2, of 2 | 389 | Sand (subsurface) | pRn59 |
| Leek-/woudeerdgronden; lichte zavel | 371 | Sand (subsurface) | pKRn1 |
| Leek-/woudeerdgronden; zandige leem; colluvium in dal | 373 | Sand (subsurface) | pLn5 |
| Leek-/woudeerdgronden; zware zavel | 372 | Sand (subsurface) | pKRn2 |
| Liedeerdgronden; zavel, profielverloop 1 | 386 | Sand (subsurface) | pMv51 |
| Loopodzolgronden; grof zand | 331 | Sand (subsurface) | cY30 |
| Loopodzolgronden; leemarm en zwak lemig fijn zand | 329 | Sand (subsurface) | cY21 |
| Loopodzolgronden; lemig fijn zand | 330 | Sand (subsurface) | cY23 |
| Mengelgronden | 127 | Sand (subsurface) | AM |
| Ooivaaggronden, lichte zavel | 184 | Sand (subsurface) | KRd1 |
| Overslaggronden | 129 | Sand (subsurface) | AO |
| Poldervaaggronden; lichte zavel | 186 | Sand (subsurface) | KRn1 |
| Poldervaaggronden; zware zavel | 187 | Sand (subsurface) | KRn2 |
| Roodoornige zandige Vechtdalgronden | 115 | Sand (subsurface) | AFz |
| Slikvaaggronden; zand beginnend ondieper dan 80 cm | 211 | Sand (subsurface) | MOo02 |
| Strandwalgronden | 140 | Sand (subsurface) | AZ1 |
| Stuifzandgronden | 133 | Sand (subsurface) | AS |
| Tochteerdgronden; zavel | 384 | Sand (subsurface) | pMo50 |
| Tuineerdgronden; lichte zavel, profielverloop 5, of 5 en 2, of 2 | 163 | Sand (subsurface) | EK19 |
| Veldpodzolgronden; grof zand | 181 | Sand (subsurface) | Hn30 |
| Veldpodzolgronden; leemarm en zwak lemig fijn zand | 179 | Sand (subsurface) | Hn21 |
| Vlakvaaggronden; grof zand | 308 | Sand (subsurface) | Zn30 |
| Vlakvaaggronden; leemarm en zwak lemig fijn zand | 306 | Sand (subsurface) | Zn21 |
| Vlakvaaggronden; lemig fijn zand | 307 | Sand (subsurface) | Zn23 |
| Vorstvaaggronden; grof zand | 297 | Sand (subsurface) | Zb30 |
| Vorstvaaggronden; leemarm en zwak lemig fijn zand | 295 | Sand (subsurface) | Zb21 |
| Vorstvaaggronden; lemig fijn zand | 296 | Sand (subsurface) | Zb23 |
| Wieringermeergronden; zand en lichte zavel, kalkrijk | 142 | Sand (subsurface) | AZW1A |
| Wieringermeergronden; zand en zavel, kalkrijk | 143 | Sand (subsurface) | AZW5A |
| Wieringermeergronden; zand, kalkrijk | 141 | Sand (subsurface) | AZW0A |
| Zandige beekdalgronden | 105 | Sand (subsurface) | ABz |
| Aarveengronden | 344 | Peat | hEV |
| Afgemaakte petgaten | 101 | Peat | AAP |
| Koopveengronden op (meestal niet-gerijpte) zavel of klei, beginnend ondieper dan 120 cm | 348 | Peat | hVk |
| Koopveengronden op bagger, verslagen veen, gyttja of andere veensoorten | 347 | Peat | hVd |
| Koopveengronden op bosveen (of eutroof broekveen) | 345 | Peat | hVb |
| Koopveengronden op rietveen of zeggerietveen | 349 | Peat | hVr |
| Koopveengronden op veenmosveen | 350 | Peat | hVs |
| Koopveengronden op zand, beginnend ondieper dan 120 cm | 351 | Peat | hVz |
| Koopveengronden op zeggeveen, rietzeggeveen of (mesotroof) broekveen | 346 | Peat | hVc |
| Madeveengronden op veenmosveen | 317 | Peat | aVs |
| Madeveengronden op zand met humuspodzol, beginnend ondieper dan 120 cm | 316 | Peat | aVp |
| Madeveengronden op zand zonder humuspodzol, beginnend ondieper dan 120 cm | 318 | Peat | aVz |
| Madeveengronden op zeggeveen, rietzeggeveen of broekveen | 315 | Peat | aVc |
| Meerveengronden met een mineraal dek 5-8 procent lutum op veen op zand, beginnend ondieper dan 120 cm | 423 | Peat | uWz |
| Meerveengronden op veenmosveen | 418 | Peat | zVs |
| Meerveengronden op zand met humuspodzol, beginnend ondieper dan 120 cm | 417 | Peat | zVp |
| Meerveengronden op zand zonder humuspodzol, beginnend ondieper dan 120 cm | 419 | Peat | zVz |
| Meerveengronden op zeggeveen, rietzeggeveen of broekveen | 416 | Peat | zVc |
| Moerige eerdgronden met een mineraal dek 5-8 procent lutum en een moerige tussenlaag op zand | 410 | Peat | uWz |
| Moerige eerdgronden met een moerige bovengrond of moerige tussenlaag op gerijpte zavel of klei | 288 | Peat | Wg |
| Moerige eerdgronden met een moerige bovengrond of moerige tussenlaag op niet-gerijpte zavel of klei | 289 | Peat | Wo |
| Moerige eerdgronden met een moerige bovengrond op zand | 412 | Peat | vWz |
| Moerige eerdgronden met een veenkoloniaal dek en een moerige tussenlaag op zand | 357 | Peat | iWz |
| Moerige eerdgronden met een zanddek en een moerige tussenlaag op zand | 421 | Peat | zWz |
| Moerige eerdgronden met een zavel- of kleidek en een moerige tussenlaag op zand | 370 | Peat | kWz |
| Moerige podzolgronden met een moerige bovengrond | 411 | Peat | vWp |
| Moerige podzolgronden met een veenkoloniaal dek en een moerige tussenlaag | 356 | Peat | iWp |
| Moerige podzolgronden met een zavel- of een kleidek en een moerige tussenlaag | 369 | Peat | kWp |
| Moerige podzolgronden met humushoudend zanddek en een moerige tussenlaag | 420 | Peat | zWp |
| Petgaten | 130 | Peat | AP |
| Veen in ontginning | 135 | Peat | AVo |
| Veenafbraakgebied | 134 | Peat | AVk |
| Veengronden met een veenkoloniaal dek op veenmosveen | 354 | Peat | iVs |
| Veengronden met een veenkoloniaal dek op zand met humuspodzol, beginnend ondieper dan 120 cm | 353 | Peat | iVp |
| Veengronden met een veenkoloniaal dek op zand zonder humuspodzol, beginnend ondieper dan 120 cm | 355 | Peat | iVz |
| Veengronden op een veenkoloniaal dek op zeggeveen, rietzeggenveen of moerasbosveen | 352 | Peat | iVc |
| Venige beekdalgronden | 104 | Peat | ABv |
| Vlierveengronden | 281 | Peat | Vo |
| Vlierveengronden op (meestal niet-gerijpte) zavel of klei, beginnend ondieper dan 120 cm | 280 | Peat | Vk |
| Vlierveengronden op bagger, verslagen veen, gyttja of andere veensoorten | 279 | Peat | Vd |
| Vlierveengronden op bosveen (of eutroof broekveen) | 277 | Peat | Vb |
| Vlierveengronden op rietveen of zeggerietveen | 283 | Peat | Vr |
| Vlierveengronden op veenmosveen | 284 | Peat | Vs |
| Vlierveengronden op zand met humuspodzol, beginnend ondieper dan 120 cm | 282 | Peat | Vp |
| Vlierveengronden op zand zonder humuspodzol, beginnend ondieper dan 120 cm | 285 | Peat | Vz |
| Vlierveengronden op zeggeveen, rietzeggeveen of (mesotroof) broekveen | 278 | Peat | Vc |
| Waardveengronden op (meestal niet-gerijpte) zavel of klei, beginned ondieper dan 120 cm | 365 | Peat | kVk |
| Waardveengronden op bagger, verslagen veen, gyttja of andere veensoorten | 364 | Peat | kVd |
| Waardveengronden op bosveen (of eutroof broekveen) | 362 | Peat | kVb |
| Waardveengronden op rietveen of zeggerietveen | 366 | Peat | kVr |
| Waardveengronden op veenmosveen | 367 | Peat | kVs |
| Waardveengronden op zand, beginnend ondieper dan 120 cm | 368 | Peat | kVz |
| Waardveengronden op zeggeveen, rietzeggeveen of (mesotroof) broekveen | 363 | Peat | kVc |
| Warmoezerijgronden (veen) | 139 | Peat | AWv |
| Weideveengronden op (meestal niet-gerijpte) zavel of klei, beginnend ondieper dan 120 cm | 396 | Peat | pVk |
| Weideveengronden op bagger, verslagen veen, gyttja of andere veensoorten | 395 | Peat | pVd |
| Weideveengronden op bosveen (of eutroof broekveen) | 393 | Peat | pVb |
| Weideveengronden op rietveen of zeggerietveen | 397 | Peat | pVr |
| Weideveengronden op veenmosveen | 398 | Peat | pVs |
| Weideveengronden op zand, beginnend ondieper dan 120 cm | 399 | Peat | pVz |
| Weideveengronden op zeggeveen, rietzeggeveen of (mesotroof) broekveen | 394 | Peat | pVc |
| Kalksteenhellinggronden | 119 | Loess | AHk |
| Lage enkeerdgronden; lemig fijn zand | 169 | Loess | EZg23 |
| Loss- en terrashellinggronden | 120 | Loess | AHl |
| Loss-, terras- en klaksteenhellinggronden | 118 | Loess | AHc |
| Loss-, tertiair- en terrashellinggronden | 124 | Loess | AHz |
| Lossige beekdalgronden | 103 | Loess | ABl |
| Veldpodzolgronden; lemig fijn zand | 180 | Loess | Hn23 |
| Geegal. en verw. zeekleigronden (eerd- en vaaggronden met ger. ondergrond); zavel en l. klei, kalkrijk | 112 | Marine Clay | AEp6A |
| Geegal. en verw. zeekleigronden (eerd- en vaaggronden met ger. ondergrond); zw. zavel en klei, kalkrijk | 113 | Marine Clay | AEp7A |
| Geegal. en verw. zeekleigronden met plaats. veen binnen 120 cm of met niet-ger. ondergrond; zw. zavel en l. klei | 111 | Marine Clay | AEm9A |
| Geegal. en verw. zeekleigronden met plaats. veen binnen 120 cm; klei | 109 | Marine Clay | AEm8 |
| Geegal. en verw. zeekleigronden met plaats. veen binnen 120 cm; zavel | 108 | Marine Clay | AEm5 |
| Geegal. en verw. zeekleigronden met plaats. veen binnen 120 cm; zw. zavel en l. klei | 110 | Marine Clay | AEm9 |
| Geegal. en verw. zeekleigronden zonder veen binnen 120 cm; zw. zavel en l. klei | 107 | Marine Clay | AEk9 |
| Hollebollige, gemoerde zeekleigronden; zw. zavel en l. klei | 116 | Marine Clay | AGm9C |
| Mariene afzettingen ouder dan pleistocee; glauconietklei | 205 | Marine Clay | MA |
| Mariene afzettingen ouder dan pleistoceen; zavel en klei | 206 | Marine Clay | MK |
| Kalkhoudende vlakvaaggronden; zeer sterk lemig, kleiig, uiterst fijn zand | 275 | Chalk | Sn14A |
| Kalkhoudende vlakvaaggronden; zwak en sterk lemig, kleiig, uiterst fijn zand | 274 | Chalk | Sn13A |
| Kleefaarde | 182 | Chalk | KK |
| Ondiep kalksteen | 183 | Chalk | KM |
| Vuursteen eluvium | 189 | Chalk | KS |
| Vuursteenhellinggronden | 121 | Chalk | AHs |
| Bergbrikgronden; siltige leem | 152 | Loam | BLb6 |
| Daalbrikgronden; siltige leem | 156 | Loam | BLh6 |
| Daalbrikgronden; zandige leem | 155 | Loam | BLh5 |
| Haarpodzolgronden; lemig fijn zand | 177 | Loam | Hd23 |
| Kuilbrikgronden; siltige leem | 158 | Loam | BLn6 |
| Kuilbrikgronden; zandige leem | 157 | Loam | BLn5 |
| Ooivaaggronden met roest beginnend dieper dan 80 cm; siltige leem in situ | 193 | Loam | Ld6 |
| Ooivaaggronden met roest beginnend dieper dan 80 cm; siltige leem; colluvium in dal | 195 | Loam | Ldd6 |
| Ooivaaggronden met roest beginnend dieper dan 80 cm; siltige leem; colluvium in hellingvoet of uitspoelingswaaier | 197 | Loam | Ldh6 |
| Ooivaaggronden met roest beginnend dieper dan 80 cm; zandige leem in situ | 192 | Loam | Ld5 |
| Ooivaaggronden met roest beginnend dieper dan 80 cm; zandige leem; colluvium in dal | 194 | Loam | Ldd5 |
| Ooivaaggronden met roest beginnend dieper dan 80 cm; zandige leem; colluvium in hellingvoet of uitspoelingswaaier | 196 | Loam | Ldh5 |
| Ooivaaggronden met roest beginnend tussen 50 en 80 cm; siltige leem in situ | 199 | Loam | Lh6 |
| Ooivaaggronden met roest beginnend tussen 50 en 80 cm; zandige leem in situ | 198 | Loam | Lh5 |
| Poldervaaggronden; siltige leem in situ | 201 | Loam | Ln6 |
| Poldervaaggronden; siltige leem; colluvium in dal | 203 | Loam | Lnd6 |
| Poldervaaggronden; siltige leem; colluvium in hellingvoet of uitspoelingswaaier | 204 | Loam | Lnh6 |
| Poldervaaggronden; zandige leem in situ | 200 | Loam | Ln5 |
| Poldervaaggronden; zandige leem; colluvium in dal | 202 | Loam | Lnd5 |
| Radebrikgronden; siltige leem | 154 | Loam | BLd6 |
| Radebrikgronden; zandige leem | 153 | Loam | BLd5 |
| Rooibrikgronden; zeer sterk lemig fijn zand | 160 | Loam | BZd24 |
| Rooibrikgronden; zwak en sterk lemig fijn zand | 159 | Loam | BZd23 |
| Tuineerdgronden; zandige leem | 166 | Loam | EL5 |
| Zeer ondiepe keileem, potklei, enz | 191 | Loam | KX |
| Daalbrikgronden; fijnzandige lichte zavel | 150 | Silt | BKh25 |
| Daalbrikgronden; fijnzandige siltige, lichte zavel | 151 | Silt | BKh26 |
| Gorsvaaggronden; lichte zavel; geen zand beginnend ondieper dan 80 cm | 208 | Silt | MOb15 |
| Mariene afzettingen ouder dan pleistoceen; fijn zand | 215 | Silt | MZz |
| Mariene afzettingen ouder dan pleistoceen; fijn zand en zavel | 214 | Silt | MZk |
| Radebrikgronden; fijnzandige lichte zavel | 148 | Silt | BKd25 |
| Radebrikgronden; fijnzandige siltige, lichte zavel | 149 | Silt | BKd26 |
Defaults
The following terrain types are used as defaults:
- Default Surface Water: Waterway
- Default Open land: Open Land
- Default Grassland: Grassland
- Default Sea: Grassland
- Default Underground: Grassland
Situational defaults:
- Default Terrain of Measure's Raise and Flatten: Grassland
- Default raised land (from water): Grassland
- Default lowered land (to water): Waterway
API Endpoints
Underground
Underground Terrain Types represent the subsoil; everything beneath the surface. The underground Terrain Type is still considered present as much as the surface Terrain Type in the same location, but is not displayed directly in the 3D Visualization. The layout of the underground can be seen using the Underground Overlay.
See List of Terrain Types for all available Underground Terrain Types.
Each surface and ground Terrain Type may contain or inherit the following attributes:
| Icon | Attribute | Unit | Layer | Range | Description |
| ANGLE_OF_REPOSE | angle (0-90°) | Ground | The different subsurface types each attain a value for the maximum slope (Dutch: talud). This value is used for creating the water edge steepness and indirect for the water depth. | ||
| BOWEN_RATIO | ratio | Surface | 0.001 to 10 | The ratio between two forms of heat transfer between this building's surface and the atmosphere. | |
| BUILDABLE | boolean | Both | 0 or 1 | Whether it is permitted to place Buildings here | |
| COLOR | Color | Both | The color of the terrain. | ||
GROUND_INFILTRATION_MD | m/day | Surface | 0.0 to 10.0 | The speed at which water can flow vertically from the surface to the unsaturated zone. |
GROUND_INFILTRATION_MD | m/day | Ground | 0.0 to 10.0 | The speed at which water can flow vertically from the unsaturated zone to the saturated zone. |
| HEAT_EFFECT | °C | Surface | Measure of impact on the Heat Stress Overlay with the UNESCO-IHE model | ||
HYDRAULIC_CONDUCTIVITY_MD | m/day | Ground | Hydraulic conductivity (K) is a measure of the ease with which water can move through pore spaces or fractures in a saturated medium. | |
HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS_MD | m2/day | Ground | This attribute represents the horizontal hydraulic conductivity (KD) of the saturated layer multiplied by the layer thickness. | |
| LIVABILITY_EFFECT | Surface | Measure of impact on the Livability Overlay. | |||
VAN_GENUCHTEN_M | fraction | Ground | 0.05 to 1.0 | Van Genuchten Soil Parameter M needed to calculate the Soil Water Retention Curve in the Unsaturated Zone. |
| PEAT_FRACTION | fraction | Underground | The fraction of the subsurface which will be considered to be peat by the Subsidence Overlay. | ||
ROOT_DEPTH_M | m | Surface | The depth of the roots of the Terrain Type. This depth is used to determine whether evaporation will occur from the groundwater. | |
SUBSIDENCE | boolean | Ground | Whether or not subsidence should be calculated for a terrain or in a given area. Subsidence is calculated when the value is not equal to 0. | |
| TERRAIN_MIX | Surface | ||||
| TEXTURE TYPE | Integer | Surface | 0 to 2 | Value used to select the terrain blend color. | |
| TOPLAYER_THICKNESS | m | Ground | The depth of the clay soil layer, as considered by the Subsidence Overlay. | ||
| VEGETATION_FRACTION | fraction | Surface | The amount of green which this Terrain Type provides per m². | ||
| WATER | nominal | Surface | Whether this Terrain Type represents a form of water (and what type). | ||
| WATER_DEPTH_M | m | Surface | The default depth of this water Terrain Type, relative to the surrounding elevation. | ||
WATER_TRANSPIRATION_FACTOR | factor | Surface | How fast this terrain can evaporate water from the ground. The weather's evaporation speed is multiplied by this factor to determine the rate of transpiration. | |
WATER_MANNING | s/(m1/3) | Surface | The Gauckler–Manning coefficient of the terrain, which is a measure of surface roughness. Used in the surface flow computation of the Water Overlay. | |
WATER_MICRORELIEF_M | m | Surface | 0 - 0.255 | The defined Microrelief in meters, which captures surface water. When captured, surface flow is halted until the defined threshold is reached. Evaporation and infiltration for water captured in Microrelief is still allowed. |
WATER_STORAGE_PERCENTAGE | fraction (m3/m3) | Ground | The percentage (as a fraction) of the ground layer volume which can be filled with water. A lower percentage means the ground layer will be able to store less water, and the saturated zone will rise higher with the same amount of water in the ground layer. |
