Api session items terraintypes
API Endpoint: /api/session/items/terraintypes/
Edit items with events described at Api session event editor terraintype.
Default Query:
https://engine.tygron.com/api/session/items/terraintypes/?token=API_TOKEN
Example Response:
  "attributes" : {
    "BOWEN_RATIO" : [ 0.4 ],
    "BUILDABLE" : [ 1.0 ],
    "COLOR" : [ -8286382.0 ],
    "GROUND_INFILTRATION_MD" : [ 1.0 ],
    "HEAT_EFFECT" : [ -6.0 ],
    "LIVABILITY_EFFECT" : [ 1.0 ],
    "ROOT_DEPTH_M" : [ 0.3, 0.3, 0.25, 0.1 ],
    "TERRAIN_MIX" : [ 0.1 ],
    "TEXTURE_TYPE" : [ 0.0 ],
    "VEGETATION_FRACTION" : [ 1.0 ],
    "WATER" : [ 0.0 ],
    "WATER_MANNING" : [ 0.03 ],
    "WATER_MICRORELIEF_M" : [ 0.002 ],
    "WATER_TRANSPIRATION_FACTOR" : [ 0.9, 1.0, 1.0, 0.9 ]
  "code" : "",
  "groundLayerType" : "SURFACE",
  "id" : 0,
  "imageName" : "land.png",
  "maquetteOverride" : null,
  "name" : "Open Land",
  "parentID" : -1,
  "version" : 1
  "attributes" : {
    "TERRAIN_MIX" : [ 0.5 ],
    "WATER" : [ 0.0 ],
  "code" : "",
  "id" : 1,
  "imageName" : "grass.png",
  "name" : "Grassland",
  "parentID" : -1,
  "version" : 2
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/terraintypes/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/terraintypes/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/terraintypes/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/terraintypes/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/terraintypes/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/terraintypes/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/terraintypes/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/terraintypes/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/terraintypes/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/terraintypes/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/terraintypes/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/terraintypes/?f=ZIPSMILE&token=API_TOKEN
Api Model Layer
API Enumeration description of Layer
Name Description
BRIDGE
SURFACE
UNDERGROUND
Api Model TerrainType
API Model description of TerrainType
Name Type Description
attributes Map<String,double[]>
code String
groundLayerType Layer Layer
id int
imageName String
maquetteOverride Map<String,double[]>
name String
parentID int Terrain Type ID
version int
