How to add and remove an Overlay
Adding and removing/deleting overlays is a generic process, however, certain overlays are dependent on other assets being present too, such as indicators, terrains, vacancy, images, etc. For more information please refer to the respective main articles for the specific overlays.
How to add an overlay:
- Open a project in the editor.
- Select the tab Current Situation in the ribbon bar.
- Hover over the Overlays to open the Overlay popup.
- Hover over any of the Overlay categories under Add New.
- Select the desired Overlay from the selected Overlay Category.
- ...or select the desired overlay from the drop down menu on the bottom of the left panel and select 'Add' from the bottom of the left panel
- The overlay icon will now appear.
1. Select Current Situation in the ribbon bar.
2. Hover over the Overlays button in the ribbon bar.
3. Select desired Overlay from pop up menu when you hover over the options in the Add New list.
4. Or select Overlays in the Ribbon bar and select desired overlay from drop down menu on the bottom of the left panel
4. Select 'Add' from the bottom of the left panel
5. The overlay icon will now appear.
How to remove an overlay:
- Select in the editor 'Current Situation' from the ribbon
- Select 'Overlays' from the ribbon bar
- Select the desired overlay from the list of active overlays on the left panel
- Select 'remove' from the bottom of the left panel
- Confirm the removal in the pop up confirmation message
1. Select 'Current Situation'
2. Select Overlays
3. Select desired overlay from the list of active overlays on the left panel
4. Select 'Remove' from the bottom of the left panel
5. Confirm the removal in the pop up confirmation message
Sometimes it can be convenient to duplicate an already existing overlay. To do so, follow the steps for removal, but select 'Duplicate' instead of 'Remove'.
