Rain area (Water Overlay)
Revision as of 13:18, 8 May 2026 by Frank@tygron.nl (talk | contribs)
A Rain area is a feature which can override the Weather's rain with a different array of values. This allows users to simulate rain clouds moving over the project area.
Dynamic rainfall defined by 101 different rain areas, which is shown in the mini-map halfway the animation. Animation is showing the last rain result
  • A maximum of 10.000 values (5.000 pairs) can be defined per rain area.
  • Up to 32.000 rain areas per Water Overlay are supported.
  • It's not required to fill the entire project area with Rain areas to use the Rain area functionality. For locations without a Rain area, the Weather's rain m is applied.
  • See the RAIN_M attribute for more information on the restriction on its values.
  • Overlapping Rain areas are not allowed. Should in any location two or more Rain areas overlap, the values of one of them is used, and the values of the others are ignored.
