Api session event editor measure
Revision as of 12:08, 1 April 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor measure Events.
Measure editing.
Name Description
ADD Add Measure for Stakeholder
DUPLICATE Duplicate specified Measure.
REMOVE Remove specified Measure.
SET_NAME Set the name of a Measure.
Specific Events:
Name Description
ADD_BUILDING Add a new Building to specified Measure
ADD_EVENT Add a new event to a Measure for a specific Action Type.
ADD_GEOTIFF Add a new GeoTIFF Spatial to a Measure.
ADD_GEOTIFF_POLYGONS Add polygons to existing polygons of a GeoTIFF Spatial of a Measure.
ADD_GRID Add a new Grid Spatial to a Measure.
ADD_GRID_POLYGONS Add polygons to existing polygons of a Grid Spatial of a Measure.
ADD_LEVEE Add a new Levee Spatial of a specified Levee to a Measure.
ADD_LEVEE_POLYGONS Add polygons to existing outer (or inner) polygons of a Levee Spatial of a Measure.
ADD_TERRAIN Add a new Terrain Spatial to a Measure.
ADD_TERRAIN_POLYGONS Add polygons to existing outer (or inner) polygons of a Terrain Spatial of a Measure.
ADD_UPGRADE Add a new Upgrade Spatial to a Measure.
ADD_UPGRADE_POLYGONS Add polygons to existing polygons of an Upgrade Spatial of a Measure.
DUPLICATE_BUILDING Duplicate specified Measure Building.
IMPORT_BUILDINGS Import Measure Building Collection
IMPORT_GEOTIFFS Import Measure GeoTIFF Collection
IMPORT_GRIDS Import Measure Grid Collection
IMPORT_LEVEES Import Measure Levee Collection
IMPORT_TERRAINS Import Measure Terrain Collection
IMPORT_UPGRADES Import Measure Upgrade Collection
REMOVE_EVENT Add a specific event of a Measure for a specific Action Type.
REMOVE_GEOTIFF Remove specified GeoTIFF Spatial from a Measure.
REMOVE_GEOTIFF_POLYGONS Remove polygons from existing polygons of a GeoTIFFs Spatial of a Measure.
REMOVE_GEOTIFF_TERRAIN_TYPE Remove the Terrain Type of a GeoTIFF Spatial of a Measure.
REMOVE_GRID Remove specified Grid Spatial from a Measure.
REMOVE_GRID_POLYGONS Remove polygons from existing polygons of a Grid Spatial of a Measure.
REMOVE_GRID_TERRAIN_TYPE Remove the Terrain Type of a Grid Spatial of a Measure.
REMOVE_LEVEE Remove specified Levee Spatials from a Measure.
REMOVE_LEVEE_POLYGONS Remove polygons from existing polygons of a Levee Spatial of a Measure.
REMOVE_TERRAIN Remove specified Terrain Spatials from a Measure.
REMOVE_TERRAIN_POLYGONS Remove polygons from existing outer (or inner) polygons of a Terrain Spatial of a Measure.
REMOVE_UPGRADE Remove specified Upgrade Spatials from a Measure.
REMOVE_UPGRADE_POLYGONS Remove polygons from existing polygons of a Upgrade Spatial of a Measure.
SET_COST Set the Cost of a Measure of a particular Cost type (construction, demolition) and wether it is fixed or Cost per cubic meter.
SET_DESCRIPTION Set the description of a Measure.
SET_EVENT Change an existing event of a specific Action Type of a Measure.
SET_GEOTIFF Change the GeoTIFFs applied by a specified Measure.
SET_GEOTIFF_AUTOMATIC_POLYGONS Let the polygons be calculated automatically based on the GeoTIFFs specified in the GeoTIFF spatial of a Measure.
SET_GEOTIFF_TERRAIN_TYPE Set the Terrain Type for a GeoTIFF Spatial of a Measure.
SET_GRID Change the Grids applied by a specified Measure.
SET_GRID_AUTOMATIC_POLYGONS Let the polygons be calculated automatically based on the Overlay specified in the Grid spatial of a Measure.
SET_GRID_TERRAIN_TYPE Set the Terrain Type for a Grid Spatial of a Measure.
SET_IMAGE Set the image of a Measure.
SET_LEVEE_ANGLE Set the angle of Levee Spatial of a Measure.
SET_LEVEE_HEIGHT Set the inner height of Levee Spatial of a Measure.
SET_LEVEE_HEIGHT_RELATIVE Set whether the inner height of Levee Spatial of a Measure is considered relative.
SET_LEVEE_TYPE Set the Levee for a specified Levee Spatial of a Measure.
SET_OWNER Set the owner of a Measure.
SET_REQUIRES_CONFIRMATION Set whether the Measure should be confirmed by other Stakeholder.
SET_TERRAIN_EDIT_TYPE Set the Edit Type of a Terrain Spatial of a Measure. This changes the way the Terrain height is adjusted: lowered, flattened or raised.
SET_TERRAIN_HEIGHT Set the inner height of Terrain Spatial of a Measure.
SET_TERRAIN_HEIGHT_RELATIVE Set whether the inner height of Terrain Spatial of a Measure is considered relative.
SET_TERRAIN_TYPE Set the Terrain Type for a Terrain Spatial of a Measure.
SET_UPGRADE_TYPE Set the Upgrade Type for an Upgrade Spatial of a Measure.
Deprecated Events:
Name Description
IMPORT_BUILDING_MEASURE Use IMPORT_BUILDINGS instead, same event with option to set existing Measure.
