Item
An Item is a generic term for any form of data for a Project in the Tygron Platform.
In general, every distinctly editable thing in a Project, such as Areas, Stakeholders, Panels, Cinematics, and Scenarios, is an Item.
Items are grouped using a Maplink: Data of a Project in the Tygron Platform stored in Items and categorized using Maplinks.
MapLink Item Group Subgroup Description
Addresses Address Current Situation CONSTRUCTION Unique Addresses with properties of units inside a Building
Buildings Building Current Situation CONSTRUCTION Physical objects (e.g. houses, trees, roads) present on the surface and below ground
Custom Geometries Custom Geometry Current Situation CONSTRUCTION 3D Model representations of Buildings
Functions Function Current Situation CONSTRUCTION Basic properties of blueprints for Buildings
Function Overrides Function Override Current Situation CONSTRUCTION Stores changes made to properties of a Function
Model Datas Model Data Current Situation CONSTRUCTION Definition of a 3D Model
Model Sets Model Set Current Situation CONSTRUCTION Set of Model Data
Textures Texture Current Situation CONSTRUCTION Properties of Textures used by 3D Models
Unit Datas Unit Data Current Situation CONSTRUCTION Basic definition of a Type of Traffic Unit
Unit Data Overrides Unit Data Override Current Situation CONSTRUCTION Stores changes made to properties of Unit Data
Areas Area Current Situation URBAN_SUBDIVISION Generic definitions of spatial Features with properties
Neighborhoods Neighborhood Current Situation URBAN_SUBDIVISION Mutually exclusive spatial Areas that divide a city or village
Plots Plot Current Situation URBAN_SUBDIVISION Plots of land owned by a particular Stakeholder
Zip Codes Zip Code Current Situation URBAN_SUBDIVISION Spatial definitions of Zip Code Areas
Zones Zone Current Situation URBAN_SUBDIVISION Spatial Areas that can restrict and provide feedback on Actions performed by Stakeholders
Excel Sheets Excel Sheet Current Situation CALCULATION Properties of imported Excel Sheets
Globals Global Current Situation CALCULATION Uniquely named Global values
Indicators Indicator Current Situation CALCULATION Key Performance Indicators used to identify and Measure potential improvements
Measurements Measurement Current Situation CALCULATION Records and inspections of Grid Overlay data
Neural Networks Neural Network Current Situation CALCULATION Properties of Neural Networks (RCNN, LLM or EMBEDDING)
Overlays Overlay Current Situation CALCULATION Definitions of calculatable raster and vector data Layers
Panels Panel Current Situation CALCULATION Customizable and calculatable interface Panels
Water Values Water Value Current Situation CALCULATION Stores categorized water volumes of Water Overlay calculations
Geo Tiffs GeoTIFF Current Situation GEOGRAPHY Properties of imported GeoTIFFs
Heights Height sector Current Situation GEOGRAPHY Tiles that create the Digital Terrain Elevation Model (DTM)
Terrains Terrain Current Situation GEOGRAPHY Spatial definition of a Terrain, situated either on the surface (above-ground) or sub-surface (underground)
Terrain Types Terrain Type Current Situation GEOGRAPHY Basic properties of a type of Terrain
Terrain Type Overrides Terrain Type Override Current Situation GEOGRAPHY Stores changes made to properties of a Terrain Type
Net Clusters Net Cluster Current Situation NETWORK Definitions of supply or demand, connected to a Net Node
Net Functions Net Function Current Situation NETWORK Shared properties of Net Lines
Net Lines Net Line Current Situation NETWORK Connection of a particular type between Net Nodes
Net Loads Net Load Current Situation NETWORK Definition of demand or supply at a Net Node
Net Nodes Net Node Current Situation NETWORK Connection Points of Net Lines
Net Settings Net Setting Current Situation NETWORK Configuration of properties related to a type of Network
Measures Measure Future Design CONSTRUCTION Predefined Actions that can be performed by Stakeholders
Parametric Designs Parametric Design Future Design CONSTRUCTION Configuration for generating spatial plans
Upgrade Types Upgrade Type Future Design CONSTRUCTION Definitions of Actions that change the Function of a Building
Levees Levee Future Design GEOGRAPHY A definition of an artificial slope or wall to regulate water levels
Costs Cost Future Design FINANCIAL Currency required for Actions performed in a Test Run
Incomes Income Future Design FINANCIAL The incoming money flow per Stakeholder
Action Logs Action Log Future Design ACTION History of performed Actions
Action Menus Action Menu Future Design ACTION Group of Actions available to Stakeholders in a Test Run
Attribute Actions Attribute Action Future Design ACTION Actions to add or update multiple Building Attributes
Event Bundles Event Bundle Future Design ACTION Collection of Events that can be Triggered as one package
Special Options Special Option Future Design ACTION Definitions of special Actions
Popups Popup Future Design INTERACTION Spatial definitions of Popups that require Stakeholder attention
Scenarios Scenario Multi Scenario CALCULATION A Scenario consists of a series of Settings, Measures and Events that can be activated in a Test Run
Money Transfers Money Transfer Multi Scenario FINANCIAL Monetary transactions between Stakeholders
Times Time Multi Scenario CONFIGURATION Stores the start Time of a Session
Stakeholders Stakeholder Multi Scenario INTERACTION Individuals or organizations that are affected by or can affect the outcome of a Project
Settings Setting Tools CONFIGURATION Project configuration Settings
Cinematic Datas Cinematic Data Tools VISUALS Definitions of automated viewport camera movement in the 3D Visualization along predefined Key Points
Particle Emitters Particle Emitter Tools VISUALS 3D Visual appearances that repeatedly emit particles according to a predefined pattern
Special Effects Special Effect Tools VISUALS Collection of one or more Particle Emitters
Weathers Weather Tools VISUALS Definition and properties of Weather events
Client Words Client Word Tools ASSETS Stored texts in different languages, used in the Tygron Client
Project Assets Project Asset Tools ASSETS Definitions of uploaded assets
Recordings Recording Tools ASSETS Stores execution Time of processes in the Tygron Platform
Sounds Sound Tools ASSETS References to audio assets
Geo Links Geo Link Tools GEO Mapping and matching configurations for Feature to Item
Geo Options Geo Option Tools GEO Settings related to creating a new Project
Geo Plugins Geo Plugin Tools GEO Configurations for importing and exporting Geo Data
Progress Progress Tools GEO Stores the Progress made by Geo Plugins during Project creation
Sources Source Tools GEO Definitions of Web Services and user imports
Error Logs Error Log Tools API Error history
Triggers Trigger Tools API Definitions of executable external API scripts during project recalculation
Chat Channels Chat Channel Community INTERACTION Definitions of Chat Channels
Chat Messages Chat Message Community INTERACTION Individual messages posted in Chat Channels
Default Words Default Word Stores translations of text parameters used in the creation of other Items
Parametric Examples Parametric Example Stored generated spatial plans
Server Words Server Word Stored texts in different languages, used in the Tygron Platform
A full list of all articles related to this topic can be found on the Items category page.
