Aquifer (Water Overlay)
Revision as of 15:44, 26 January 2024 by Frank@tygron.nl (talk | contribs)
The aquifer is an additional definition for the ground, allowing for ground horizontal flow different from the ground terrain's GROUND_INFILTRATION_MD.
AQUIFER_KD | m²/day | The hydraulic conductivity of the aquifer, which dictates the speed at which water can flow horizontally through the underground. | n/a | |
AQUIFER_DATUM | m + datum | The datum height at which the aquifer layer is situated. | n/a |
- The aquifer only functions if its hydraulic conductivity is greater than 0. If it is 0 or less the aquifer is disregarded, and the GROUND_INFILTRATION_MD of the ground terrain is used.
- The aquifer functionality is also used to model drainages.
