Water relative (Water Overlay)
Revision as of 15:21, 23 February 2023 by Frank@tygron.nl (talk | contribs)
WATER_RELATIVE | boolean | Determines if the water level for all water terrains in this water area is set to a relative or a datum height. | n/a |
- In case the attribute Water Relative is configured to a value above 0, the Water Level is interpreted as the height above the datum. This means that the water level is raised relatively above the digital terrain height, which can spatially vary a lot.
- The water level can alternatively be provided as a prequel, in combination with the inundation level.
