Water relative (Water Overlay)
Revision as of 13:55, 17 January 2022 by Frank@tygron.nl (talk | contribs) (Created page with "{{Overlay keys|<onlyinclude> {{Overlay keys|type=row|group=Water Overlay |key=WATER_RELATIVE |unit={{boolean}} |description=Determines if the water level for all terrain wat...")
WATER_RELATIVE | boolean | Determines if the water level for all water terrains in this water area is set to a relative or a datum height. | n/a |
- In case the attribute Water Relative is configured to a value above 0, the Water Level is interpreted as the height above the datum. This means that the water level is raised relatively above the digital terrain height, which can spatially vary a lot.
- The water level can alternatively be provided as a prequel, in combination with the inundation level.
