Terrain root depth m (Water Overlay)
Revision as of 12:41, 6 October 2020 by Rudolf@tygron.nl (talk | contribs)
Icon | Attribute | Unit | Layer | Range | Description |
ROOT_DEPTH_M | m | Surface | The depth of the roots of this surface terrain, relative to the surface. Water can be drawn from the underground and evaporated if the roots can reach it. |
Terrains can be configured with plant-related attributes, similar to constructions configured as crops and foliage, allowing it to draw water from the underground and evaporate it.
- For plants to evaporate water, both the ROOT_DEPTH_M and the WATER_EVAPORATION_FACTOR must be appropriately configured.
- When a construction is present in any given location, the values for evaporation in the underground will overrule any values set by terrain in the same location. To model underground evaporation without a construction, set these attributes on the applicable terrain type instead.
- When there is no construction present on the surface, and the terrain has a ROOT_DEPTH_M of 0, the amount of evaporation which takes place in that location is 0.
