Breach height (Water Overlay)
Revision as of 13:57, 19 June 2019 by Rudolf@tygron.nl (talk | contribs)
- The Breach height attribute can be defined as values over time, using an attribute array. This allows users to more dynamically define the height used in the Breach flow formula.
- The initial surface height at the breach (both active and inactive) cells are lowered to the lowest value of the defined breach height array.
