Left Panel
(Redirected from Left panel)
The left panel provides access to sub-items and functionality of the item currently selected on the ribbon bar. For example, when the indicators button is currently selected on the ribbon bar, access to the current active indicators in the project is available.
Left panel overview
This example shows the left panel when the indicators button is selected in the ribbon
Search and Select a filter
- The left panel starts with a search field, useful for lists with a lot of items.
- Most Left Panels have additional filters to select. These are dependent on the type of Item. Examples of what you can filter on are:
- Stakeholder: specify the stakeholder related to that item.
- With Attribute (has Attribute), with a button to select a particular existing Attribute and a field that displays the selected Attribute.
- With Attribute (non-zero value), with a button to select a particular existing Attribute and a field that displays the selected Attribute. The item should have a non zero value for that attribute.
- Category; Building should be of a particular Category.
- Function; Building should be of a particular Function.
Items
- The left panel features different context-sensitive items. Selecting an item displays its properties, which can be adjusted in the right panel.
Adding and removing Items
The bottom of the left panel provides access to adding and removing items (in this case indicators).
