Breach measurement distance m (Water Overlay)
BREACH_MEASUREMENT_DISTANCE_M | m | 0 to 10000 | Distance from the breach area to the automatic downstream water level measurement point, in the direction of the breach. | 100 |
- This distance is only taken into account when not using a manually defined Breach level area.
- In order to place the measurement the breach area must also have a BREACH_ANGLE. Together they determine the location at which the point of measurement is placed.
- The downstream water level of the breach is used in the Verheij–van der Knaap growth formula.
- The placement-location picker starts at the breach area and moves cell by cell in the direction of the specified angle, up to the distance set by the attribute (e.g., 100 m). When it reaches a location above the breach level, it stops and places the measurement point in the previous grid cell. This helps prevent illegal placement on top of features such as buildings.
- If all grid cells along the line are above the breach level, the measurement point is placed in the first cell beyond the breach area.
- In the edge case where another water object (e.g., a weir) or a limit area completely blocks the line, the measurement point cannot be placed.
