Ribbon
Revision as of 09:10, 12 November 2026 by Frank@tygron.nl (talk | contribs) (→Ribbon bar dropdown menu)
The ribbon is located in the top part of the editor. It is a tabbed header that organizes tools into logical categories for easy access.
Editor layout showing the Ribbon, Left Panel, User Main Interface, Right Panel and Bottom Panel.
Ribbon overview
The ribbon at the top consists of 2 parts, the ribbon header and the ribbon bar.
The ribbon header provides access to the File Menu and five other tabs:
Clicking on one of these five tabs reveals a menu on the ribbon bar corresponding to the selected tab.
The tab that is currently active is colored, while the non-active tabs are grey.
Ribbon bar and popup menus
The ribbon bar dropdown menu
Hovering over a ribbon bar button displays a popup menu providing shortcuts to the left panel, project items, or documentation. Clicking on a ribbon bar button directly opens the left panel of the corresponding item.
Calculation Panel
The Calculation panel helps you to manage the calculation time of your project. Hover over the Calculation Cloud (a cloud-shaped icon) to open the Calculation Panel.
File
Main article: File menu.
File Pane
