Api session event participant
Revision as of 15:33, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/
API Endpoints for Endpoints for user Actions (e.g., Building construction) in a test run/impact Session.
Name Description
action_menu_set_active Set an Action Menu active for a Stakeholder.
attribute_action_plan Stakeholder applies an Attribute Action within a MultiPolygon.
building_plan_construction Stakeholder plans a new Building of a Function with an amount of floors and a MultiPolygon.
building_plan_demolish Stakeholder plan the demolition of an owned Building.
building_plan_demolish_polygon Stakeholder plans the demolition of Building parts intersecting a MultiPolygon in a particular Layer.
building_plan_upgrade Stakeholder plans the upgrade of Buildings within a MultiPolygon.
building_revert_polygon Stakeholder reverts demolished, changed and planned Buildings within a MultiPolygon back to their original state.
event_bundle_apply_server_events Stakeholder applies server side events of an Event Bundle.
map_buy_land Stakeholder plans a land purchase with in the MultiPolygon for a given price.
map_levee Stakeholder plans a Levee for a MultiPolygon, an absolute or relative height and an angle.
map_lower_land Stakeholder lowers land and adds a waterway.
map_raise_land Stakeholder raises land within the MultiPolygon by one meter and removes water.
map_sell_land Stakeholder plans to sell owned land within the MultiPolygon to another Stakeholder for a given price.
measure_cancel_construction Stakeholder cancels a planned Measure.
measure_plan_construction Stakeholder plans a Measure.
money_transfer_give Stakeholder transfers money to another Stakeholder.
net_cluster_set_load_attribute Stakeholder sets an Attribute to a value, for each Net Load of a Net Cluster.
net_cluster_set_load_attributes Stakeholder sets set the value of the Attributes for each Net Load of a Net Cluster.
net_cluster_set_state Stakeholder sets the Net state for all Net Loads of a Net Cluster.
net_cluster_set_state_for_net_type Stakeholder sets the Net state for Net Loads of a Net Cluster and Net Type.
net_cluster_set_states Stakeholder sets the Net state for all Net Loads of a Net Cluster, per Net Type.
panel_answer Stakeholder selects an Answer (Panel) in a Panel.
parametric_design_plan Stakeholder plans a generated Parametric Design.
popup_answer Stakeholder Answer (Panel)s a Popup.
popup_answer_with_date Stakeholder Answer (Panel)s a Popup with an additional date.
restore_land Stakeholder creates a Measure that removes water Terrains and flatten its land using a MultiPolygon.
stakeholder_set_location Stakeholder's view is moved to the location in the 3D Visualization.
zone_add_function_category Stakeholder adds an allowed Function Category to a Zone.
zone_remove_function_category Stakeholder removes an allowed Function Category from a Zone.
zones_set_categories Stakeholder sets the allowed Function Categories per specified Zone.
