Ground Price
Revision as of 09:36, 13 October 2026 by Frank@tygron.nl (talk | contribs)
Elevation model in relation to Terrains, Height sectors and Elevation GeoTIFFs.
Buy land (and buying and selling of Buildings) between Stakeholders, to change ownership in the project map, are an integral part of the Tygron Platform. Therefore, ground prices are also implemented. In addition to a fixed price per surface unit, the Tygron Platform allows fixed prices for raising or lowering the terrain. After the ground price for buying and selling land is set in the editor, users can even negotiate and adjust the ground price later on in the actual session.
Ground price types available
To better visualize action costs, the Tygron Platform implements three ground-related prices: the price per surface unit, the cost to raise terrain from water level, and the cost to lower terrain to water level.
Ground price
The ground price is the purchase price of an area in an amount of money per surface unit. Depending on the regional selections made in the editor/ New Project Wizard, the values can be very different between the regions. For example: the European region calculates the ground price in Euro per square meter, while the US region uses dollars per square foot.
Ground price panel in the editor, accessed by hovering over Terrains in the editor ribbon bar and selecting Edit ground prices.
Price to lower land from ground to water level
The price to lower land from ground to water level is important when actions adjust terrain height. For example, if an action creates open water to be able to improve the water storage of an area, the costs reflect the terrain adjustment.
Price to raise land from water to ground level
The price to raise land from water to ground level also plays its part in the Tygron Platform. When an action raises the ground level with one meter to resolve a flood danger, costs involved with adjusting the terrain height are calculated based on this price.
