Max water bottom m (Water Overlay)
Revision as of 14:08, 15 July 2026 by Frank@tygron.nl (talk | contribs)
This functionality can be used to resolve some instances where an irregular bottom of waterways would inhibit the proper flow of water. Because in slow-moving models there is little difference to to deep or shallow water if the amount of water flowing to adjacent cells is minimal, setting this attribute to a sufficiently low value can allow water to flow uninhibited by artifacts in the height of the waterway's bottom.
