Ground bottom distance m (Water Overlay)
Revision as of 14:06, 15 July 2026 by Frank@tygron.nl (talk | contribs)
The ground bottom distance m setting can be configured in the Simulation Settings step of a Water Overlay wizard when the Ground water mode is set to Complete.
The groundwater level cannot go below this depth, relative to the surface. The maximum amount of water that can be stored underground is equal to this attribute multiplied by the local terrain's WATER_STORAGE_PERCENTAGE.
Ground bottom distance.
