Bottom Panel
Revision as of 09:36, 15 July 2026 by Frank@tygron.nl (talk | contribs)
The bottom panel has multiple functions in the Editor. Its primary function is to display the controls for tools in the editor, such as the brush panel or the Free cam.
The additional function of the bottom panel is to allow for editing of certain properties. This includes a number of properties for the entire project, such as the environment settings. It also allows for editing the details of properties of items, such as Events connected to scenarios or the function pairs of a type of upgrade.
The Tygron Editor. The Ribbon (top), Left Panel, User Main Interface (center), Right Panel, and Bottom Panel.
Tools in the bottom panel
The bottom panel is used to access the following tools:
Free camera
The bottom panel with the free cam tool.
Main article: Free cam.
The free camera tool allows greater freedom in moving the camera around in the editor.
Multi-select
The bottom panel with the multi-select tool.
Main article: Multi-select.
The multi-select tool allows the user to select multiple buildings in the project, and modify them en masse.
Brush
The bottom panel with the brush.
Main article: Brush.
The brush allows the user to modify the spatial aspect of a number of elements in a project, such as buildings or zones.
Project properties in the bottom panel
The bottom panel is used to access the following properties of the project:
Environment
The bottom panel with the environment properties.
Main article: Environment.
The visualization of the environment in the project, such as the look of the water and direction of the sun.
Elevation
The bottom panel with the elevation tool.
Main article: Terrain height brush.
The variation in terrain height in the 3D Visualization.
Item properties in the bottom panel
The bottom panel is used to access the following properties of items in the project:
Event's type and parameters
The bottom panel when editing events.
Main article: Event
When an event is added to an item in a project, that event's type and parameters can be changed.
Indicator's Targets
The bottom panel when editing indicators.
Main article: Indicators
When an indicator is added to the project, the indicator's target(s) can be changed.
Upgrade's Function Pairs
The bottom panel when editing upgrades.
Main article: Upgrade Types
When an upgrade type is added to the project, that upgrade's definition of which functions turn into which other functions can be changed.
