Api session event participant
Api session event participant Endpoints.
API Endpoints for Endpoints for user actions (e.g. build Building) in a testrun/impact Session.
| Name | Description |
| action_menu_set_active | Set a category active for a Stakeholder. |
| attribute_action_plan | Apply an Attribute Action. |
| building_plan_construction | Plan a new Building in the MAQUETTE map. |
| building_plan_demolish | Plan the demolition of a Building in the MAQUETTE map. |
| building_plan_demolish_polygon | Plan the demolition of a Building in the given polygon in the MAQUETTE map. |
| building_plan_upgrade | Plan the upgrade of Building in the given polygon in the MAQUETTE map. |
| building_revert_polygon | Revert polygon to orginal CURRENT map situation. |
| event_bundle_apply_server_events | Apply a bundle of events on the serverside for a particular Stakeholder. |
| map_buy_land | Buy the land definied by the polygon for given price. |
| map_levee | Create a Levee with a given height and Area. |
| map_lower_land | Lower land to create open water. |
| map_raise_land | Raise land by one length unit. |
| map_sell_land | Buy the land definied by the polygon for given price. |
| measure_cancel_construction | Cancel a Measure planned by an Stakeholder while in pre-construction phase. |
| measure_plan_construction | Plan construction of a Measure by an Stakeholder that is not yet planned. |
| money_transfer_give | Give money from one Stakeholder to another. |
| net_cluster_set_load_attribute | For each Net Load of a Net Cluster, set the value of the attribute. |
| net_cluster_set_load_attributes | For each Net Load of a Net Cluster, set the value of the attribute. |
| net_cluster_set_state | Set TimeState for all Net Load of Net Cluster. |
| net_cluster_set_state_for_net_type | Set TimeState for Net Load of Net Cluster, based on Net Type. |
| net_cluster_set_states | Set TimeState for all Net Load of Net Cluster. |
| panel_answer | Stakeholder has selected an answer in a Panel. |
| parametric_design_plan | Parametric Design Plan |
| popup_answer | Stakeholder answers a Popup. |
| popup_answer_with_date | Stakeholder answers a Popup with an additional date. |
| restore_land | Stakeholder restores land back to orginal state. |
| stakeholder_set_location | Set the location of a Stakeholder in the 3D world. |
| zone_add_function_category | Add a FunctionCategory that is allowed to be built within a Zone. |
| zone_remove_function_category | Remove a FunctionCategory so it cannot be build within the Zone. |
| zones_set_categories | Sets the allowed Building categories for specified Zone. |
