Plot
Revision as of 14:34, 20 April 2026 by Frank@tygron.nl (talk | contribs)
This article is a stub. The following information should be added:
  • Revision of term "Construction" has left unclear sentences.
  • Page implies that data is related to plots as defined in urban planning, which is not the case.
  • This type of data hardly ever needs to be touched by end-users, but there is no information steering users away from unduely editing this data directly.
Plots related to Buildings
A Plot is a part of land (Dutch:perceel) which has one owner and which has most of the time only one building on it or exists of for example agricultural land. Together with Buildings it describes the ownership in the Tygron Platform.
Plots in the Tygron Platform belong to one stakeholder and can mostly have one building on top of it or one Building. The plots are used and visualized for/in the Ownership Overlay.
The Plots menu can be found in the Current situation tab:
Editor → Current Situation (Ribbon tab) → Administrative (Ribbon bar) → Show Plots (Dropdown)
