Breach angle (Water Overlay)
Revision as of 09:24, 27 February 2024 by Frank@tygron.nl (talk | contribs)
Icon | Key | Unit | Range | Description | Default value |
BREACH_ANGLE | geo angle (0-360°) | -1.7976931348623157E308 to 1.7976931348623157E308 | The angle at which water flows out through the breach. | n/a |
- The flow direction will be more realistic when the angle is provided correctly.
- When provided, this angle will be applied to the calculated flow speed from the breach flow formula and the speed and direction will be applied to the cells to which water is added.
