Infiltration factor s (Water Overlay)
Revision as of 16:28, 29 January 2024 by Frank@tygron.nl (talk | contribs)
INFILTRATION_FACTOR_S | factor | This value is multiplied with the surface infiltration speed and can be used to adjust the infiltration over time. Default is 1 (no adjustment). | 1 |
Array
This attribute can be defined as values over time, using an array of values defining interpolation-time. This allows users to more dynamically define the infiltration factor used in both the Surface and Ground infiltration formulas.
- How to add and remove an Attribute
- How to configure a dynamic infiltration factor for a Water Overlay
