Ground watertable with surface (Water Overlay)
Revision as of 15:19, 29 January 2024 by Frank@tygron.nl (talk | contribs)
![](/w/images/7/76/Wateroverlay_wizard_ground_watertable_with_surface.png)
The ground watertable wit surface setting can be configured in the Output Overlays step of a Water Overlay wizard when the ground watertable result is selected as an output overlay.
Icon | Attribute | Unit | Range | Description | Default value |
GROUND_WATERTABLE_WITH_SURFACE | boolean | Whether the ground watertable result type should also include the surface water level, when the groundwater levels are close to the surface. | True |
Measurement of a waterway for a water table result of a Water Overlay set to include the surface for the ground watertable.
Measurement of a waterway for a water table result of Water Overlay set to exclude the surface for the ground watertable.
