Ground bottom pressure m (Water Overlay)
Revision as of 09:08, 24 January 2024 by Frank@tygron.nl (talk | contribs) (Frank@tygron.nl moved page Seepage fluctuation (Water Overlay) to Ground bottom pressure m (Water Overlay))
| File:Waterwizard icon seepage fluctuation.png | SEEPAGE_FLUCTUATION | m | Optional: The additional head of higher areas outside the project causing groundwater seepage. | 0 |
This optional seepage fluctuation is added to the spatially defined Bottom pressure and resistance, to calculate seepage.
This attribute can be defined as values over time, using an array of values, defined as pairs of the start-time and its value from that point on.
