Clause (TQL)
A TQL query statement consists of a command, either Select or Update, and a list of clauses. The clauses provide further specification of the query statement, or a refinement, spatially or property wise. A clause consists of a clause parameter and a clause value, where currently the only supported operator between the parameter and value is IS.
List of Clause Parameters
Spatial
| Param | Value | Description | Limits search polygon |
| AREA |
Integer (Item ID), ID, X, Y, XC, YC XA, YA, XK or YK |
Area with ID | true |
| AREA_WITH_ATTRIBUTE | Attribute | Area with non zero Attribute value | true |
| BUFFER | decimal | Buffer the limiting search Polygon with this value. | true |
| GRIDVALUE | decimal | Only include Grid Overlay cells that have a value equal to the one specified | true |
| MINGRIDVALUE | decimal | Only include Grid Overlay cells that have a value larger than or equal to the one specified | true |
| MAXGRIDVALUE | decimal | Only include Grid Overlay cells that have a value smaller than the one specified | true |
| NEIGHBORHOOD |
Neighborhood with ID | true |
| NEIGHBORHOOD_WITH_ATTRIBUTE | Attribute | Neighborhood with non zero Attribute value | true |
| STAKEHOLDER |
Stakeholder with ID Only include Plots that are owned by the stakeholder with this ID Only include Items that are related to this stakeholder |
true |
| STAKEHOLDERTYPE | Stakeholder Type | Stakeholder Type with this value Only include Plots that are owned by this type of Stakeholder |
true |
| TERRAIN |
Terrain of Terrain Type with ID | true |
| TERRAIN_WITH_ATTRIBUTE | Attribute | Terrain is of Terrain Type with non zero Attribute value | true |
| ZONE |
Zone with ID | true |
| ZONE_WITH_ATTRIBUTE | Attribute | Zone with non zero Attribute value | true |
Attribute
| ATTRIBUTE | Attribute | The Attribute used for Buildings to obtain a value. | false |
| ATTRIBUTE_MIN | decimal | Only include Buildings that have an Attribute value larger than or equal to this value. | false |
| ATTRIBUTE_MAX | decimal | Only include Buildings that have an Attribute value smaller than this value. | false |
| ATTRIBUTE_MULT | Attribute | Multiply the calculated value with the value of this Attribute for a Building | false |
Grid
| GRID |
Grid of Grid Overlay with ID | false |
| GRID_WITH_ATTRIBUTE | Attribute | Grid of Grid Overlay with non zero Attribute value | false |
| GRIDTYPE |
Grid Type X, Y, XA, YA |
Grid of Grid Overlay with specified type | true |
| OVERLAY |
Item
| ADDRESS |
Address with ID | false |
| AREA |
| BUILDING |
Building with ID | false |
| FUNCTION |
Function with ID | false |
| GLOBAL |
Global with ID | false |
| GRID |
| INDICATOR |
Indicator with ID | false |
| LEVEE |
Levee with ID | false |
| MEASURE |
Measure with ID | |
| NEIGHBORHOOD |
| OVERLAY |
| PANEL |
Panel with ID | false |
| STAKEHOLDER |
true |
| TERRAIN |
| ZONE |
Net
| NET_LINE |
Net Line with ID | false |
| NET_TYPE |
Net type X, Y, XA, YA |
Only Net Items of this Net Type | false |
| NET_FUNCTION |
Net Function with ID | false |
| NET_LOAD |
Net Load with ID | false |
| NET_CLUSTER |
Net Cluster with ID | true |
Property
| CATEGORY |
Category X, Y, XA, YA |
Category with this value Buildings of this Category |
false |
| CATEGORYMULT | Category Value | Multiply the calculated value with this Category Value of a Building | false |
| FUNCTIONMULT | Function Value | Multiply the calculated value with this Function Value of a Building | false |
| NAME | String | Name of the Attribute or Global to select | false |
| RESIDENCE | boolean | When true, consider only Buildings that are Residences | false |
| ROAD_SYSTEM | boolean | When true, consider only Buildings that are part of the road system | false |
true |
| TERM |
Client Word Server Word |
Client Word or Server Word with name. | false |
Specifier
| INDEX |
positive integer X, Y, XA, YA |
Allows to specify which value in an Attribute' s value array to select. | false |
| LAYERTYPE |
Layer X, Y, XA, YA |
Only include Buildings and Terrains that are part of this Layer | true |
| MAP |
Map Type X, Y, XA, YA |
Only Items present in this Map Type | true |
| RELATION | Relation | Allows to convert a specific selected Item to an other Item it is related to. | false |
| STATE | Timestate | Only include Buildings and Measures that are in this Timestate | false |
| TIMEFRAME |
timeframe X, Y, XA, YA |
Specifies which Timeframe to select when processing a particular Grid | false |
