Difference (Overlay)
Revision as of 14:42, 20 February 2023 by Frank@tygron.nl (talk | contribs)
The Difference overlay displays the difference between the original and the maquette or planned state of a specific (dynamic) grid overlay to which the Difference overlay is linked as child overlay. A hover panel provides additional information on the occurring difference in a hovered over cell in the 3D Visualization, in the same units or terms as the parent grid overlay uses. The Difference overlay is primary created to visualize the impact of a specific action or measure on its parent overlay, and on the project in general.
A few examples of where the Difference overlay can be useful are:
- the impact that a change in traffic density has on traffic noise and traffic air pollution
- the effect of a water measure on the way houses or crops are impacted by excessive rainfall or flooding
- insight in the impact that different simulated scenarios have on the same start situation
Adding and removing
How to add the Difference overlay:
- Select in the editor 'Current Situation' from the ribbon
- Select 'Overlays' from the ribbon bar
- Select the specific overlay from the drop down menu of where you want to see the difference of
- In the panel on the right side of the Overlay check the Show Difference Option Box
- In the Overlay ribbon, click on see Difference Map
How to remove the Difference overlay:
- Select the desired overlay from the list of active overlays on the left panel
- Select 'remove' from the bottom of the left panel
- Confirm the removal in the pop up confirmation message
