Limit area model attribute (Water Overlay)
Revision as of 08:57, 17 October 2022 by Frank@tygron.nl (talk | contribs)
| File:Waterwizard icon | LIMIT_AREA | nominal value | Whether and how calculations in the simulation should be limited to specific locations of the 3D world. | Entire map |
| 0. | Entire map: Calculations are performed across the entire map. Water can flow anywhere. |
| 1. | Limit to Water Areas: Calculations are only performed in the locations where water areas are present. |
| 2. | Limit to specific Areas: Calculations are only performed in the locations where limitation areas are present. |
- The overlay attribute name for this option is LIMIT_AREA, which is similar to the default Overlay key for Limitation areas.
- When any limit is in effect, water can flow between valid locations, even if those locations are defined through different relevant features (e.g. 2 adjacent water areas).
- In step 1 of the Water Overlay Wizard, the to be calculated area can be selected. When chosen for the option Limit to specified areas, an extra step in the wizard is added.
