Bridge elevation (Water Overlay)
Revision as of 07:56, 10 February 2022 by Rudolf@tygron.nl (talk | contribs)
Icon | Attribute | Unit | Range | Description | Default value |
BRIDGE_ELEVATION | nominal | Specifies the mode by which bridges are include in the elevation model, used for the water calculations. | n/a |
0. | Lowest: The lowest terrain height under or near the bridge is used. |
1. | Terrain: Bridges are excluded from the DEM, allowed water to flow as if they didn't exist. |
2. | Bridge: Bridges and floating Constructions are included in the DEM, blocking water flow. |
- When using Bridge mode, it is still possible to model the flow from one side of a bridge to the other by using a Culvert.
