Max infiltration m (Water Overlay)
Revision as of 15:52, 9 February 2022 by Frank@tygron.nl (talk | contribs) (Created page with "{{Overlay attributes|<onlyinclude> {{Overlay attributes|type=row|overlay=Water |attribute=INFIL_ONLY_BOTTOM_DISTANCE_M |unit=m |description=Assumed distance under the terrain...")
| INFIL_ONLY_BOTTOM_DISTANCE_M | m | Assumed distance under the terrain surface which can store infiltrated water | n/a |
The groundwater level cannot go below this depth, relative to the surface. The maximum amount of water that can be stored underground is equal to this attribute multiplied by the local terrain's WATER_STORAGE_PERCENTAGE.
{{article end |notes=
- In case the ground water mode is set to Complete, this distance is overwritten by [[Ground bottom distance m (Water Overlay)|Ground bottom distance m]
