Terrain water transpiration factor (Water Overlay)
Revision as of 07:14, 3 September 2020 by Rudolf@tygron.nl (talk | contribs)
Terrains can be configured with plant-related attributes, similar to constructions configured as crops and foliage, allowing it to draw water from the underground and evaporate it.
  • For plants to evaporate water, both the ROOT_DEPTH_M and the WATER_EVAPORATION_FACTOR must be appropriately configured.
  • When a construction is present in any given location, the values for evaporation in the underground will overrule any values set by terrain in the same location. To model underground evaporation without a construction, set these attributes on the applicable terrain type instead.
  • The groundwater level reduction is inversely proportional to the WATER_STORAGE_PERCENTAGE, as the contribution of a given volume of water to the groundwater level increases when the capacity for water storage in the underground layer decreases.
  • When there is no construction present on the surface, and the terrain has a WATER_EVAPORATION_FACTOR of 0, the amount of evaporation which takes place in that location is 0.
