Watershed Overlay
Revision as of 14:20, 7 May 2020 by Frank@tygron.nl (talk | contribs) (Created page with "thumb|420px|right|Example of the Watershed overlay The watershed overlay calculated where surface water will end up based on the DEM or a Wa...")
File:Watershed overlay.PNG
The watershed overlay calculated where surface water will end up based on the DEM or a Water Overlay's direction result.
Modules
In order to configure a Heat Stress Overlay, a module has to be selected. The module can be configured by opening the Heat Overlay Wizard.
The selectable modules are:
Example of the UNESCO heat stress overlay
Template:Heat Module buttons
