Max water bottom m (Water Overlay)
Revision as of 13:52, 20 June 2019 by Rudolf@tygron.nl (talk | contribs)
| Attribute | Unit | Description |
| MAX_WATER_BOTTOM_M | m + datum | The maximum height for the bottoms of water terrains. Any water terrain with a bottom at a higher datum height has its bottom lowered to this value. |
- This functionality can be used to resolve some instances where an irregular bottom ofwaterways would inhibit the proper flow of water. Because in slow-moving models there is little difference to to deep or shallow water if the amount of water flowing to adjacent cells is minimal, setting this attribute to a sufficiently low value can allow water to flow uninhibited by artifacts in the height of the waterway's bottom.
