Hydrological attributes of terrains (Water Overlay)
Revision as of 08:30, 12 June 2019 by Rudolf@tygron.nl (talk | contribs) (Rudolf@tygron.nl moved page Terrain attributes (Water Overlay) to Hydrological attributes of terrains (Water Overlay) without leaving a redirect: Conform naming convention to "Hydrological attributes of constructions (Water Overlay)")
Terrains in a project have a number of hydrological properties which can influence the flow of water in a project. Because there is always both surface and underground terrain defined for the entirety of the project area, all cells are affected by all properties of terrains, unless a construction is present with overwriting values.
Icon Attribute Unit Type Description
WATER_EVAPORATION_FACTOR factor Surface How fast this terrain can evaporate water from the underground. The weather evaporation speed is multiplied by this factor to determine the rate of evaporation.
WATER_STORAGE_PERCENTAGE fraction Underground The percentage (as a fraction) of the underground volume which can be filled with water. A lower percentage means the underground will be able to store less water, and the saturated zone will rise higher with the same amount of water in the underground layer.
WATER_MANNING s/(m1/3) Surface The Gauckler–Manning coefficient of the terrain.
