Water Overlay
Revision as of 08:30, 11 April 2019 by Frank@tygron.nl (talk | contribs)
A water overlay is an overlay for which results are calculated by the Water Module. The Water Module in the Tygron Platform is an implementation of a 2D grid based shallow water model based on the 2D Saint Venant equations. The module is further enhanced with infiltration, evaporation, groundwater flow and hydraulic structures. Its calculations form a simulation of an arbitrary amount of time, during which water is allowed to move.
Variants
The water module can be called upon by adding one of the following overlays to a project. Each variant has a number of parameters tuned to best fit specific use-cases.
Results
A water overlay generates different results. For further information about these outcomes, see also results and result types.
