How to remove an Attribute
The right panel allows you to add remove Attributes. The top half displays existing Attributes, along with the option to remove them.
Many Items in a Project, ranging from Stakeholders to Overlays to Buildings, have Attributes, representing properties that can be added, changed and removed. The Attribute Tab in the right panel provides a consistent way of managing attributes of an Item.
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to remove an attribute:
  1. Select the type of data to remove an Attribute from.
  2. Switch to the "Attributes" tab.
  3. Scroll to the Attribute you want to remove, if neccesary.
  4. Click on "Remove" next to the Attribute you wish to remove.
  5. The Attribute has now been removed.
